11-13-2009, 11:23 PM | #1 |
44
Rep 319
Short Meisterschaft GTS review
I got the Meisterschaft GTS exhaust today and installed it. I wish it came with all the hardware needed for the install. 2 of the exhaust hangers are actually bolted onto the muffler but the oem muffler has nuts that are welded on. I had to run around looking for a bolt and nut that would work. The left exhaust is also hugging the right side of the opening in the bumper (I'll attempt to fix this tomorrow).
I haven't heard any other exhausts on the e92 but this exhaust is LOUD below 3k rpm. Its almost obnoxiously loud. I used to have various hks, greddy, tanabe exhausts on my Hondas in the past and this exhaust is louder than any of those. I'll try to post a longer review with pictures and video sometime this week. *EDIT* It's not as loud this morning as I remember it being last night but hitting the gas with the windows rolled up is still pretty loud with a heavy low drone. Both sets of tips are hugging the right side of the opening but not touching. It looks like the whole exhaust is shifted to the right. Last edited by isabayo; 11-14-2009 at 09:59 AM.. |
11-13-2009, 11:30 PM | #3 |
44
Rep 319
I installed mine at a diy garage with lifts, tools, etc... The garage had many bolts nuts washers etc but not anywhere close to the selection of a hardware store. I'll measure the oem bolt tomorrow but It was about 2.5 - 3" long. I found a bolt and nut that was close to the oem length and used that. TIP, if you're installing this yourself, unbolt all the exhaust hangers from the car, its must easier to get the rubber hangers off that way.
11-13-2009, 11:33 PM | #4 |
I Drive Slow To Save Gas :D
26
Rep 464
Im planning to do this by myself, yeah i was thinking about just removing them and then popping them off with wd-40 would be easier. i wonder why they would make an exhaust and not give us hardware. I remember paying only 400 dollars for an exhaust on my lexus gs400. and it came with evvvverything!
11-13-2009, 11:35 PM | #5 | |
44
Rep 319
11-13-2009, 11:37 PM | #6 |
26
Rep 464
i checked, there wasn't anything there. i dumped the whole box out onto a garbage bag. there was nothing. i think they might of wrapped it along with the exhaust, im going to check tomorrow, when i unwrap it.
11-13-2009, 11:41 PM | #7 |
44
Rep 319
11-14-2009, 12:13 AM | #8 |
65
Rep 1,676
man isn't this one of the most expensive ones they make for our car?? you think they could at least put the hardware in there
how bad of a drone do you have??
Street- 08 E92 M3- Sparkling Graphite/ Fox Red/6sp
Track- 10 CRF 250-PR2 Race Motor/Ohlins TTX Susp Hauler- 06 Ford Skyjacker F250 4WD |
11-14-2009, 06:23 AM | #11 |
yodog
197
Rep 5,025
Same here. It was one of my choices but I was going to wait until a forum member purchased. I'm looking for a quiet exhaust or something equivalent to the "sport" exhausts.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
11-14-2009, 07:41 AM | #12 |
249
Rep 3,157
honestly if you want a quiet but really fast exhaust its Akrapovic
it produces just about the same amount of HP as the cattless ones.
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
11-14-2009, 08:51 AM | #13 |
44
Rep 319
11-14-2009, 09:57 AM | #15 |
44
Rep 319
11-14-2009, 10:28 AM | #16 |
Meh
928
Rep 781
Drives: M3CS & Cayman S
have you tried rotating the connecting pipes if possible? how about bending the hangars?
11-14-2009, 10:49 AM | #17 |
86
Rep 2,148
I found that they made a sport version called the HP Touring. It's supposedly right under the GT and GTR in sound level.
11-14-2009, 03:46 PM | #20 | |
44
Rep 319
I got my left muffler to line up pretty well in the exhaust cutout but the right muffler is still hugging the right side. Not sure if this is a manufacturing defect but one bracket on the left muffler is slightly bent to allow the tips to be centered in the opening while the identical bracket on the right side is not bent causing it to hug the right side of the opening. Pictures are posted below. The mufflers are a little low because I'm going to be putting on a rear diffuser in the next few days, I didn't want the exhaust tips to melt the diffuser. This is the left muffler bracket: Heres the identical bracket on the right muffler: and some installed photos |
11-14-2009, 04:37 PM | #21 |
yodog
197
Rep 5,025
Damn, if my mufflers look like that, I'd much rather have the RPi system.
11-14-2009, 09:56 PM | #22 |
26
Rep 464
day1, maybe if you put some think washers on the inside of that bracket on the right, it could center it:-) and make it further from the right, bc that looks really close.
