11-09-2009, 09:05 PM | #1 |
Moderator
673
Rep 4,737
New Theory About Stock Brake/Pads Overheating
So I was inspecting my suspension after a track weekend today, and I noticed that the cross drilled holes on my front rotors were almost completely filled by brake dust...
I know that the stock pads are notorious for being very dusty, so I guess on the track under heavy braking, all the brake dust starts to collect in the cooling holes, thus blocking the passage of air radially through rotor into the vanes to adequetly cool the component. This then leads to the overheating of the rotors and all hell breaks loose. From my understanding most people with better brake fluid, SS lines, and track pads can run w/o major issues. So I guess the stock pads are what really causes the brake failures? What do you all think? (image borrowed from the other thread, notice how the holes are plugged) |
11-09-2009, 09:23 PM | #2 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
The stock pads probably can't handle as much heat as a track pad which will have a high-heat compound which is probably a lot harder than the stock pad. So your stick pads get hot and spongy which leads to fade.
I don't think the dust in the holes makes much of a difference.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
11-09-2009, 09:24 PM | #3 |
374
Rep 8,033
My understanding is that the holes are meant to evecuate the gases from the pads, so they are not cooling holes. My guess is that they do not have any significant effect on venting of the rotors/air flow. That is mainly a function of the internal vane geometry and air supply (radially) to the internal vanes. I've seen some interesting CFD analysis reports on this.
11-09-2009, 10:17 PM | #4 |
Professional lurker
129
Rep 376
Agree, the holes do virtually nothing for cooling. The cooling is done primarily by the internal cooling vanes which have no relation to the drilling. Have you ever seen a real race car with cross drilled rotors?
11-09-2009, 10:37 PM | #5 |
Moderator
673
Rep 4,737
Yes I have, but slotted rotors must have a different internal vane geometry vs. drilled. If the drilled holes have no cooling use at all, why did people come up with them in the first place?
So how do slotted rotors evecuate the gases from the pads since they do not have the holes? |
11-10-2009, 12:55 AM | #6 | |
80
Rep 961
They aren't intended to cool the rotor. What may be happening though is that brake dust can go through the holes and fill up (then totally block) the airway between the cooling vanes inside the rotor. I doubt this would really happen, but my wheels used to get lovely "spots" on them where the holes on the edge of the rotor threw brake dust out at speed with stock pads. Slotted rotors vent outgassing from the pad by channeling it radially through the slots out past the edges of the pad. The gas and dust don't share the airway inside the rotor. It's not as good for wiping water, but it's still pretty good, and in the end it doesn't weaken the disk like drilling or cast-in holes do. |
11-13-2009, 02:37 PM | #7 |
99
Rep 1,575
The post above makes a lot of sense. But i cant imagine the cross drilled holes would play no roll in cooling even if thats not the main purpose for them. Im not saying the dust is the reason the brakes fade like they do, Im just saying the holes most likely cool faster than brakes with no holes.
Mine look the same if not worse
11-13-2009, 07:17 PM | #8 |
1571
Rep 8,076
When I wash my car, just spraying down the wheels clears out most of the dust. I can't imagine that it is a huge hinderance to air flow through the holes.
