11-03-2009, 07:03 PM | #1 |
134
Rep 204
ABS kill switch for experienced drivers on track, anyone??
I had an ABS Kill switch in my E46 M3.
It's great for trackdays and even better for drifting track day's (Yes, WE have special driftin' trackday's in Europe ) In the E46 i took fuse 33 out and put the switch in. And put the switch in the dash. When you spin, flick the switch, kill the ABS and lock up your brakes at the right moment to keep you beloved M3 out of the wall or wherever. I have a trackday next sunday and wanna put it in my E92 M3 again. Didn't check the fuse chart yet. Please don't respond to this post if you don't know/or doubt this advanced driving technique with locking up the brakes etc... Anybody have this, and on witch fuse?
F13 M6 CP GT3 | Mineral White | 20'' BC Forged Center Locks | Fully Loaded | JB4/Meth | Custom GT3 Widebody Kit + Aero | Catless DP/X-Pipe | Turner StrackSport Discs/Pagid Brake Pads |
11-04-2009, 09:39 AM | #2 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
Nice idea. I asked about this many times when I had my e46. Having ABS put me into a wall has been one of my biggest fears for a long time (all the way back to my '90 Taurus SHO).
I don't believe anyone has the clarity of thought to hit the switch in the middle of a spin, but I can see turning off the ABS completely for track days (Says the man who tracks with DSC on). The risk of locking up a rear while trail braking some corners is there, however. |
11-04-2009, 11:31 AM | #3 | |
134
Rep 204
With my E46 M3 i didn't like how the car handeled with the ABS off (fuse 33 out) and the ESP doesn't work. Witch was off anywaz but FYI. I'm gonna instal the ABS killswitch tomorrow c if it works and post an DIY. Also gonna change my brake discs, pads and fab some custom brake backplates for my custom brake coolin'system DIY Link I´ll updat my DIY on that. And put some FRS in the brake system. Then i´ll b ready for my Spa Trackday on Sunday. I´ll let you guy´s know how the car handels with the ABS off. Cheers.
11-04-2009, 03:41 PM | #4 | |
Veni Vidi Vici
89
Rep 2,750
The sequence for me was usually:
I've never had the time between 2 and 3 to flip a switch. For me 3 is an instant response to 2. I suppose a real cool head could hit the switch before hitting the brakes. BTW, I've done this in a race where I completed a 360 with both feet in and continued without losing my position (downhill coming out of the cyclone at Thunderhill in a non-ABS car). |
11-04-2009, 04:40 PM | #5 |
817
Rep 7,887
I actually like having the ABS on as it does allow a lot more trail braking than without it working.On my E30 racecar we used to turn the ABS off only at tracks like Mosport were you needed to be able to lock it down in a spin to avoid the many walls around there.Not sure either about hitting a switch to disable in the middle of a spin though.
11-04-2009, 05:14 PM | #6 | |
258
Rep 5,012
I'm glad I'm not brave enough to be thinking about those mods . Good luck. |
11-04-2009, 05:54 PM | #7 | |
134
Rep 204
Guess it's a 'Pro' trick. About you list. The trick is to lock the brakes at the correct time during the 'spin' @ witch the momentum of the car is 'pointing' in a 'safe' direction. When the brakes are locked at this time and the wheels lose 'grip' the car will follow the path of it's momentum.
Hope this inspires the people who didn't knew about this.
11-04-2009, 05:58 PM | #8 |
134
Rep 204
You'll lose track of the button during corrections, unless you check the position of the button with full lock. It actually a good idea...but you'll need to program it.
11-04-2009, 06:05 PM | #9 |
205
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
Is it really this simple to bypass the ABS system without possible side affects to the other systems?
11-04-2009, 06:17 PM | #10 | |
134
Rep 204
But don't forget it's a last resort measure.....the other option is to not lock up your brakes and spin or slide in to something while hearing and feeling the ABS pump working.....thinking DO'H!!!!!!!!
11-04-2009, 07:17 PM | #11 |
128
Rep 1,144
Jeeze, you all must be gods on the track. It's a totally different animal to threshhold brake without ABS. I've been off many times in race cars that don't have ABS.
11-05-2009, 07:34 AM | #12 |
Veni Vidi Vici
89
Rep 2,750
I understand that there are competition grade ABS systems that do allow you to lock all four wheels. I think Porsche has one and possibly BMW. I believe the cost is astronomical. Any knowledge of this out there?
11-05-2009, 07:44 AM | #13 |
817
Rep 7,887
I have allways wondered why ABS systems did not have a default when you stood on the pedal to allow full line pressure at the wheels when full pedal pressure was applied.I remember 1 really hairy time after spinning in a C5 Corvette and going backwards with a hard pedal & no braking force.That is the only time that I can recall ABS causing a safety issue but I suppose being able to shut it off would be a good idea if you could actually do it or remember to do it in the the middle of a spin.
11-05-2009, 09:06 AM | #14 | |
205
Rep 1,864
Drives: F80 M3
There was discussion about having to go to an aftermarket ECU and harness such as MOTEC and ditch the stock DME, not for the faint of heart. |
11-05-2009, 01:58 PM | #15 |
199
Rep 4,318
11-05-2009, 02:21 PM | #17 | |
374
Rep 8,033
Seriously, I saw the exact same thing happen in a club race at Tremblant this summer, but it happened in the middle of a tight pack. Amazingly, there was no contact, and the guy kept on going...
11-05-2009, 02:43 PM | #18 |
Veni Vidi Vici
89
Rep 2,750
Just for clarification:
I was in some traffic. Everyone gets on the binders when someone in front spins, unless they know they can get by without getting clipped. The track was wide there, and the inside line was clear. I didn't lose a spot because I believe I was in last place already. |
