09-19-2009, 11:41 AM | #1 |
65
Rep 1,676
Front OEM Rotor/Caliper on rear??
does anyone know if the front brake setup will fit on the rear of the m3?? i notice the front is bigger so i was thinking of either putting a front on the rear and have the same size front, front and back, or putting a BBK on the front then putting my front on the rear
any input on this would be great. as other may have read bf i am trying to avoid buying a full BBK kit as i don't track but do appreciate great brakes and having a full BBK on my last E46 M3 left me with the wonderful taste of awesome brakes but don't want to spend that money again so i thought of the idea of above, any info if these will fit would be great thanks H
Street- 08 E92 M3- Sparkling Graphite/ Fox Red/6sp
Track- 10 CRF 250-PR2 Race Motor/Ohlins TTX Susp Hauler- 06 Ford Skyjacker F250 4WD |
09-19-2009, 11:52 AM | #2 | |
42
Rep 442
This CAN NOT be done because caliper mounting on the front & rear are different. Also, the front are much bigger because the front brakes do most of the braking on all cars. The rear is just for assistance & for the traction control functions. So pretty much if you want bigger calipers on the rear, you will have to go BBK.
08 E90 M3, JrzB/BB, 360 Forged 8 Mesh, H&R Springs, RPI Scoops, Eisenmann Sport Exh, VRS Lip, CF Decklid, CF Diffuser, OSS LED AE, Rear Headrest V1, '09 iDrive Controller, Euro Rear Fog, OEM BlackLine TL, MRTM Design E90 Pedals & Door Lock Studs
09-19-2009, 12:17 PM | #3 | |
65
Rep 1,676
i could care less if i get flamed. i am not a mechanic so that is why i asked if i could put a front set up on the rear to get a bigger rear brakes without going BBK
i realize the front are bigger that is why i wanted to put it on the rear and then go with a BBK up front or just have 2 front set ups thank you for the info i appreciate it do you know the mm size of the oem brakes?? like i know most BBK set ups are 380mm front and 355mm rear. do you know the sizes of the oem ones so i can see how much bigger it is going to be from oem thanks H Quote:
09-20-2009, 05:56 PM | #4 |
Bored at work....
890
Rep 5,391
360mm frnt
350mm rear I beleive
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
09-20-2009, 09:18 PM | #5 |
65
Rep 1,676
thank you, wow so the BBK's are not much bigger
