BMW M3 Forum (E90 E92)
      09-08-2009, 09:19 PM   #1
onefastdoc
115
Drives: 2016 F80 M3
12mm spacer + H&R + racing = rubbing
So I ran my E90 M3 at an autocross recently and found out a few things. I have 12mm spacers all around and H&R springs with OEM 19" wheels. The rear tires rubbed the plastic liner on the rear fender during the autocross. I didn't notice during the run, but on inspection afterward, the tire had rub marks, and the plastic liner and tire residue built up on it. So basically, anything greater than 10mm is going to rub in the rear if you corner hard.
I also noticed that with the H&R springs, the OEM shocks did not seem to have enough dampening. In one section under hard braking, there was a bump that would really unsettle the car in the front. The springs seemed too stiff for the shocks, even on the sport EDC setting. Whatever, I sort of knew this when I got the springs. They feel fine on the street, but this setup is not ideal for the track. I'll get a better idea after I run at Willow Springs. That might convince me to get some coilovers.
OneFastDoc
2012 R35 GT-R Full Bolt On E85 (600whp)
2016 F80 M3
2008 E90 M3 sold
2007 E92 335i (369whp, 354wtq) sold
      09-08-2009, 09:23 PM   #2
JC919
Drives: CSL
I have 10mm spacer and they get pretty close...
[SIGPIC][/SIGPIC]
2007 GT3 Clubsport w/CGT buckets in Scotland
2003 CSL, SG, Alcon BBK SOLD
2002 M5, SSII/Blk and bone stock. In storage back home in TX
2008 M3, AW/Blk 6MT, lots of track stuff SOLD
      09-09-2009, 04:27 AM   #3
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
Thanks for the heads up. I'm not 100% satisfied with my H&R's either. Looks like the only spring setup that's for sure won't hurt your performance in anyway is the Dinan solution. Too bad it's so expensive (for just springs) and the drop is even (.5 F/R) so it still gives you that "raised" look in the front that comes w/ the BMW 3 series..
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle
Special Thanks: Gintani | OETuning | eAs
m3post
