08-30-2009, 04:44 PM | #1 |
98
Rep 1,092
Drives: F82 M4 CP
95RON vs 98RON
The 135i can run on either 95RON or 98RON, with performance obviously affected by the lower octane fuel. What do most people run their 135i's on?
I ask this as due my test drive the traction control light came on a lot and there was only about a quarter tank of fuel. Then on delivery there was a full tank and the light only comes on when I give it a big bootful. I'm thinking that perhaps the dealership filled it up with 95 and that's why it seems to be missing the extra edge. Thoughts/comments?
2017 BMW M4 Competition - Mineral Grey
2009 BMW 135i - Titan Silver - SOLD |
08-30-2009, 05:14 PM | #2 |
210
Rep 3,288
Drives: anything given a chance
BP Ultimate98 without exception. Performance fuel for a performance car and it's better for your engine.
08-30-2009, 05:27 PM | #3 |
145
Rep 3,016
If, and only if i can only have 91 (say stuck out in a shithole somewhere), I use a fuel additive - good old Wynn's! I keep two full bottles of Octane booster and two bottles of injector cleaner in the boot.
But with an NA engine, it's not that imperative i use 98RON. Having said that, i usually get 98RON unless it's over $1.50 a litre. |
08-30-2009, 05:41 PM | #4 |
24
Rep 895
There's no difference in power output using 95RON and 98RON. The benefit of using higher octane fuel is in terms of greater resistance to pre-ignition (important for a boosted engine), and improved fuel economy (98 is slightly denser than 95 so you get slightly lower L/100km). The traction control light has SFA to do with the grade of fuel in the tank. What you observed with the traction control light was probably just a combination of differences in road service and the weight of your right foot. Another possibility is that if the test drive car was a brand newy and still on it's first tank, then the tyres would probably also still have had a layer of mould-release on them -- slippery stuff that reduces traction until it wears away.
08 BMW 135i Sport Coupe | Manual | Sparkling Graphite | Coral Red Boston Leather | 10 Speaker Hi Fi
08-30-2009, 06:12 PM | #5 | |
145
Rep 3,016
08-30-2009, 07:06 PM | #6 |
Retired trackie
36
Rep 1,527
Use anything you like. It is your car .
I use BP Ultimate not even Caltax Vortex 98 which I have vouchers for. I have been staying away from V Power since 6 months ago when the V Power racing was gone.
TAKA 一仔BLOGブログ:
BMW 1 series M 2011! Delivered 18/11/11. |
08-30-2009, 07:12 PM | #7 |
2819
Rep 7,640
08-30-2009, 08:35 PM | #9 |
Retired trackie
36
Rep 1,527
It is very difficult to compare as we are in different state. The Shell in Vic comes from a different source as in NSW and SA.
The BP are imported and I suspect they are the same stuff. To be honest, they must have changed since last BP no ultimate crisis.
TAKA 一仔BLOGブログ:
08-30-2009, 08:58 PM | #10 |
24
Rep 895
Jeez, steady on there. People will start to talk!
08-30-2009, 09:19 PM | #11 |
145
Rep 3,016
08-30-2009, 09:38 PM | #12 |
210
Rep 3,288
08-30-2009, 09:55 PM | #13 |
13
Rep 286
I would always use the highest octane fuel for a NA high compression or turbo car, since knocking/predetonation can definitely be an issue - esp during those long hot aussie summers! That said, if you're using lower octane fuel, the engine management should be able to detect it and adjust the timing accordingly.
Modded 135i RHD Bumblebee |
08-30-2009, 10:37 PM | #14 |
44
Rep 1,883
I was of the understanding that engines with knock sensors (like the N54), would give a higher output using a fuel with a higher knock rating (like 98)? Something to do with the engine able to run more advanced timing using a higher octane fuel...
Driving - Manual E90 M3 (Melbourne Red/Black).
Riding - BMW R1200RS Sport. |
08-30-2009, 10:43 PM | #15 |
50
Rep 1,474
Drives: 135i MT, LMB, ProNav
I always use BP Ultimate when I can. Have twice filled up with 95RON though and experienced no discernible difference in performance.
Fun Car: 135i Manual LeMans Blue / Beige Leather / Grey Poplar / pro nav / euro plates. Delivered 24 June 08 Family Car: Land Rover Discovery 4 SDV6 Spare Car: Volvo V70 Sydney Car: MB 420SEL |
08-30-2009, 10:49 PM | #16 | |
50
Rep 1,474
08-30-2009, 11:16 PM | #17 | |
98
Rep 1,092
Drives: F82 M4 CP
It may have been in my mind, but the traction control light certainly came on more the first time I drove the car. And finally, I concur with the sentiments on Ultimate 98. I would rather push my car home than put Shell into it.
08-30-2009, 11:36 PM | #18 |
13
Rep 286
Yup. Basically with a turbo car, because you're compressing the air before it goes into each cylinder, the air that goes into the cylinder is hotter than a normal NA engine. The hotter the air is, the more likely you will get predetonation - eg: the fuel in the cylinder exploding before the spark plugs fire. As you can imagine, predetonation is bad. So, if its detected by the engine management system, the ECU can retard the timing (and cause power loss). Higher octane fuels are more resistant to predetonation than normal fuel. The higher the octane, the more resistant it is.
08-31-2009, 12:36 AM | #19 | |
24
Rep 895
On the other hand, I could be completely wrong, and I'm happy to be corrected!
08-31-2009, 12:57 AM | #20 | |
Rep 54
Well it's possible the N54 is different from most other cars but generally these days cars explore greater advance to improve specific efficiency and therefore power. This change happened across the industry from the late 90s. There was a time with a WRX for example that you did an ECU reset occasionally or after a low octane load of fuel so it would relearn but that ceased being relevant post 1998. I'd be surprised if the N54 was any different. I know the supercharged Toyota does exactly that and thats a low boost pressure engine. |
08-31-2009, 01:06 AM | #21 |
98
Rep 1,092
Drives: F82 M4 CP
The AM (advanced multiplier) reset is still relevant in WRX's, but I think they "relearn" eventually by themselves. My MY05 had to be reset manually a few times until I finally learned that Optimax (now V-Power) was not the best thing to run in my car.
08-31-2009, 04:43 PM | #22 |
398
Rep 9,156
i've always used 98RON but i always fill up at shell because it's closest to my house. why do most people think bp ultimate is better than v power? or is there not much in it?
