08-25-2009, 03:49 PM | #1 |
8209
Rep 18,823
Drives: BMW
▀▄ eas - Macht Schnell Ashtray gauge Panels for e8x 1-Series now available
Monitor your engine’s vitals and race with confidence while adding some style points with our ashtray gauge panel for your 1 Series.
Unlike other vendors - these panels are being offered with or without gauges so YOU can choose what goes into your BMW's interior. The Macht Schnell gauge panel is an exact component replacement for your stock BMWs ashtray, comfortable housing three 52mm gauges within and angled for easy viewing. The textured finish allows an OEM feel as if this were offered from your local BMW parts counter. Injection molded from ABS plastic, this panel will resist warping or bending in high-heat applications. The smooth textured finish is a perfect match for your BMWs interior, giving the OEM-like appearance you expect. The Macht Schnell ashtray gauge panel mounts using the factory ashtray mounting holes with no cutting, drilling or gluing necessary. Ashtray can be replaced at any time if the vehicle is turned in or sold. Gauges not included, packages are offered fully loaded with Stri gauges if desired. Features: - Gauge panel houses three 52mm gauges - Injection molded ABS plastic construction - Textured finish to match interior design - Mounts utilizing factory ashtray mounting locations, no drilling necessary Macht Schnell - e8x 1-series ashtray gauge panel http://www.europeanautosource.com/pr...oducts_id=2384 Models Supported: 2008+ e8x 1-Series
08-25-2009, 03:49 PM | #2 |
8209
Rep 18,823
Drives: BMW
Stri 52mm Digital Stepper Drive (DSD) Series, Black Dial/White LED
Stri DSD warning gauges offer full function, features, and extreme accuracy.Driven by rugged stepper motor, control by advance microprocessor, DSD is the latest technology in precise monitoring device. DSD gauge series is equipped with laboratory grade sending units.
Click the accompanying images above to be brought to its specific page on our site. Available Gauges: - Digital Stepper Drive (DSD) Series, Boost Pressure (30psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Boost Pressure (45psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Water Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Pressure (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Exhaust Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Voltmeter (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Fuel Pressure (Imperial Measurement) ** Not to be used on N54 applications DSD gauge series are equipped with laboratory grade sending units. All electrical pressure sensors are temperature compensated for highest accuracy. Features: - Glass domed lens to eliminate glare - Warning - User Preset - Peak Recall - Automatic Self Calibration - Short Circuit Auto Detect - Racing Spec Sensors - Extreme Accuracy - 270 Degree Full Sweep - High Resolution - Sequential Open/Closing Mode - LED Backlighting - Titanium Finish Casing Last edited by tom @ eas; 08-25-2009 at 07:19 PM.. |
08-25-2009, 03:50 PM | #3 |
8209
Rep 18,823
Drives: BMW
Stri 52mm Digital Stepper Drive (DSD) Series, White Dial/Amber LED
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 08-25-2009 at 07:09 PM.. |
08-25-2009, 03:51 PM | #4 |
8209
Rep 18,823
Drives: BMW
Stri 52mm Digital Stepper Drive (DSD-SLM II) Smoked Series, Black Dial/White LED
Unlike the standard DSD Series, the DSD-SLMII turn completely black when unlit for a "stealth" appearance. Click the accompanying images above to be brought to its specific page on our site. Available Gauges: - Digital Stepper Drive (DSD) Series, Boost Pressure (30psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Boost Pressure (45psi Imperial Measurement) - Digital Stepper Drive (DSD) Series, Water Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Oil Pressure (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Exhaust Temperature (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Voltmeter (Imperial Measurement) - Digital Stepper Drive (DSD) Series, Fuel Pressure (Imperial Measurement) ** Not to be used on N54 applications DSD gauge series are equipped with laboratory grade sending units. All electrical pressure sensors are temperature compensated for highest accuracy. Features: - Glass domed lens to eliminate glare - Warning - User Preset - Peak Recall - Automatic Self Calibration - Short Circuit Auto Detect - Racing Spec Sensors - Extreme Accuracy - 270 Degree Full Sweep - High Resolution - Sequential Open/Closing Mode - LED Backlighting - Titanium Finish Casing
08-25-2009, 03:51 PM | #5 |
8209
Rep 18,823
Drives: BMW
Stri 52mm Digital Stepper Drive (DSD-SLM II) Smoked Series, Black Dial/Amber LED
08-25-2009, 03:52 PM | #6 |
8209
Rep 18,823
Drives: BMW
reserved
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 08-25-2009 at 04:45 PM.. |
08-25-2009, 04:45 PM | #7 |
8209
Rep 18,823
Drives: BMW
reserved 2
08-26-2009, 11:13 AM | #9 | |
8209
Rep 18,823
Drives: BMW
A few overnight orders will be leaving soon.
08-28-2009, 01:18 PM | #10 |
8209
Rep 18,823
Drives: BMW
All inquiries replied and orders shipped.
Looking forward to seeing your pictures soon.
09-10-2009, 04:36 PM | #11 |
8209
Rep 18,823
Drives: BMW
All orders shipped and inquiries replied.
09-14-2009, 05:22 PM | #13 | |
8209
Rep 18,823
Drives: BMW
Of course, final production pieces are black as in post #1. We'll update the thread as soon as ours is installed or as customers submit completed photos.
10-02-2009, 04:15 PM | #16 | |
8209
Rep 18,823
Drives: BMW
Here's the gauges in our e92 Project M3:
10-02-2009, 04:21 PM | #17 |
8209
Rep 18,823
Drives: BMW
Installed in our Project 135 w/ Stri DSD White backlit gauges:
10-02-2009, 06:40 PM | #18 |
121
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Beautiful! In my top3 of next things to buy, maybe work will pick up and I'll be able to order soon! I'm planning methanol and interestingly I won't get a meth kit that doesn't make a gauge that will be compatible with this kit.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
