08-24-2009, 07:05 AM | #1 |
817
Rep 7,887
Reset Brake Warnings?
The warning for brake life remaining is on my I-drive.The brake sensors have never been activated,but I am on my 4th pad change.Is there a way to reset the warning without having to get it reset at the dealer?
08-24-2009, 08:41 AM | #2 |
72
Rep 1,171
As far as I am aware this can be done with the Bavarian Technic (BT) OBD reader software. I do not own it thus havent tried myself but reading the manual and their site I am pretty positive you can do it. BT owners will be able to confirm.
08-28-2009, 12:50 AM | #3 |
Rep 38
PROCEDURE TO VIEW OR RESET SERVICE ITEMS IN THE INSTRUMENT CLUSTER E90, E91, E92, E60, E61, E63 AND E64 (includes M models)
Turn ignition to Terminal 15. (key on engine off ) Press and hold the Instrument Cluster Set/Reset button for 10 seconds. The upper display in the Instrument Cluster will be illuminated with a Service Item (example: An oil can is the designation for Oil Service). The lower display in the Instrument Cluster will indicate the remaining time or mileage left for that Service Item (example: 14000). Pressing the button repeatedly will allow the display to scroll through all of the Condition Based Service Items. Press and hold the Instrument Cluster Set/Reset button again and the lower display screen will indicate "OK" or "DUE". Pressing the Instrument Cluster Set/Reset button again will allow the "RESET" to appear in the lower window for that service. Releasing and reapplying the button one more time will reset the service displayed in the upper window only. Repeat the procedure for any additional service reset needs. |
08-28-2009, 08:11 AM | #4 | |
817
Rep 7,887
08-28-2009, 08:38 AM | #5 |
817
Rep 7,887
It worked but with a different technique than described by Krazy M3
My car does have i-Drive so maybe its different. hold the reset button as described for 10 seconds use the bc button on the end of the turn signal stack to call up the reset.Hold the button down till it scrolls up the milege on the display screen on the I -Drive and you are done.I did this for both my front & rear pads and it now indicates 18000 for the front & 32000 for the rear.Thanks again! Last edited by Gearhead999s; 08-28-2009 at 09:08 AM.. |
08-28-2009, 10:38 AM | #6 | |
258
Rep 5,012
- Hold cluster button for 10 seconds until first service item shows up. Same thing. - Now, how do you choose front and rear pads? Rapidly click the cluster button to go down the list of CBS options, or use the OBC button at the end of the stalk? - Once you have the appropriate service, then you press the OBC button at the end of the stalk for 10 seconds until reset, correct? And where do you put the iDrive before starting this? On the service window, or does it turn on by itself? Thanks man. Sorry for the questions, but it's VERY important to get this right, especially under warranty. Don't want to reset something else by mistake . Take care. |
08-28-2009, 11:21 AM | #7 | ||||
817
Rep 7,887
[QUOTE=elp_jc;5773465]Great info. Hey, could you elaborate on the technique a little please ?
- Quote:
You hold it till the clock goes out and you are done. Quote:
