08-14-2009, 04:30 PM | #1 |
342
Rep 1,805
dyno chart! before/after eisenmann exhaust
Had exhaust installed at HYEVON MOTORS in Westminster, CA. Gave me a great deal and did top quality work.
Ran my first dyno...on dyno dynamics in 3rd Gear. Car was stock first ran 362hp on best run...then with exhaust ran 366.7hp...with stronger gains in torque. EDIT: ALSO A FEW PEOPLE MENTIONED TO WAIT TO DYNO, CAUSE EXHAUST NEEDS TO BREAK IN AND ECU NEEDS TO ADAPT...SO MIGHT GO DYNO IN A FEW WEEKS....ANY THOUGHTS? Last edited by TheKosherStogie; 08-15-2009 at 02:12 AM.. |
08-14-2009, 05:26 PM | #4 |
Scared money don't make money.
67
Rep 1,448
Drives: 2009 E92 M3 DCT
Holy Jesus...Autowave's dyno is reading stock M3's at 360+hp?? I knew they always made their dyno read high, but that's just absurd.
2009 E92 M3/DCT/Alpine White/Fox Red/Carbon Leather OE Tuned 402 whp & 303 wtq/Gintani X-pipe/MXP Axle Back/Rogue Pulley/AFE Stage 2/Cosmetics By IND & EAS HUGE THANKS: Gintani, OE Tuning, and EAS |
08-14-2009, 05:30 PM | #5 |
286
Rep 6,007
Interesting.... IND showed it at about 16hp I believe. I know theirs was on the Race system. I don't think there's too many other independent owners that have compared just OEM to Eisenmann upgrade alone.
08-14-2009, 05:57 PM | #7 |
I like cars
329
Rep 5,052
An axle back just isn't going to give you much, if anything, on an otherwise stock car. The stock muffler flows pretty well especially considering how quiet it is.
My photostream: http://www.flickr.com/photos/racelap/
08-14-2009, 06:03 PM | #8 |
248
Rep 6,125
sammyrusso,
Thanks for sharing. IF you don't mind can you pm me how much you paid for your exhaust please? Thanks!
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
08-14-2009, 06:13 PM | #9 |
342
Rep 1,805
was the Race....same day...within 2hrs...
also i ran another m3(w/ power chip/ eisen exhaust) at the drag...and i pulled on...so i wondering since i bought my car used if maybe the previous owner had chipped it. . how do u know they alter'd theyre dyno? autowave told me they dyno'd the rd motor...said it ran around 430whp...is that high? |
08-15-2009, 05:32 PM | #12 |
504
Rep 4,033
Agreed.
16 F82 M4 DCT - ZCP - JB4 - 556WHP / 570WTQ
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH |
08-15-2009, 06:30 PM | #13 |
342
Rep 1,805
i agree to the above...but im sick off people and companies claiming their exhaust especially axle back give 15-20hp...so i wanted actual proof of what it does do..as i wish other people would do to!!! dont be cheap people DYNO!!! before and after every mod!!
08-17-2009, 02:01 AM | #14 |
Sleeper
29
Rep 281
Although I thought it was common knowledge that the Eisenmann does not make much power (no matter how loud it is), thanks for showing us your graphs. The more information that is out there the better!
08-17-2009, 08:40 AM | #16 |
249
Rep 3,157
How much does the Eisenmann Race make???
I have seen IND dyno out 15whp and now I see only 6 WHP . so does anyone have a confirmed answer? I did not dyno mine but I feel there is good power being made.
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
08-17-2009, 09:29 AM | #17 |
Bates '08 Interlagos Launch
126
Rep 1,230
What are the M3's typically Dyno'ing at (whp) in stock form? I'd like to know because I'm going to get a dyno and want to know if my car is inline with average #'s. I know it depends on the dyno as well. The place I'm going to uses a DynoDynamics.
Custom Exhaust Project: Bates Valvetronic exhaust: http://www.m3post.com/forums/showthread.php?t=253661 -- Exhaust Mod pics in here: http://www.flickr.com/photos/40236795@N03/
DON'T BUY Race Ready Performance electronic cutout valves. Here's why: http://www.m3post.com/forums/showthr...40#post9589740 |
08-17-2009, 09:47 AM | #18 | |
Sleeper
29
Rep 281
http://bmw.pencilgeek.org/DynoDB.html But really the best thing you can do is to ask the place where you're dynoing at if they've done M3s previously and what numbers they put down.
08-17-2009, 11:31 AM | #19 |
123
Rep 2,097
Most M3's on a Dyno Dynamics should make 310-320whp stock. This has been seen at both rpi and Gintani.
08-17-2009, 11:33 AM | #20 |
126
Rep 1,230
I've looked on there but didnt see a lot of non modded cars.. Just curious what the generally assumed average dyno # was for a oem car.
08-17-2009, 11:54 AM | #21 |
BimmerPost Supporting Vendor
9596
Rep 10,884
This exact reason is why Eisenmann does not release dyno figures. IND's dyno tests were done as a response to the numerous inquiries from the public, asking for dyno data. Dyno data is rarely a reliable way to predict the efficiency of an exhaust system. I would attribute the low gains seen in this test to a lack of break in- when the system is brand new it will not flow as well as it does once it's broken in. As you do more runs with the exhaust, you will see progressively higher gains as the system is broken in.
Here is another dyno run performed by Evolve in the UK: http://www.e90post.com/forums/showth...Eisenmann+dyno Here is a link to Pencil Geek's dyno database, for a closer look: http://bmw.pencilgeek.org/DynoDB.html Eisenmann's testing showed a 32% improvement in flow over the OEM rear muffler section, and I would expect this figure to be the most accurate. In any case, our test was performed by an independent shop- Fall Line Motorsports, a highly qualified BMW race shop with years of BMW race victories in their portfolio. The test was performed on a car they provided, using their testing equipment, under their conditions.
08-17-2009, 06:46 PM | #22 | |
342
Rep 1,805
i will be goin back to dyno the car again once the exhaust is broken in....also anyone recommend how many miles to wait? also going to go to the gintani shop and use their dyno..just to see where my car reads on their dyno |
