KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
08-12-2009, 07:13 PM | #1 |
yodog
197
Rep 5,025
H&R/Lowering springs & 285/35/19
Anyone have experience with this size tire in the rear and if it'll rub? My wheel size is 10" +20 if that helps. I just want to make sure I don't rub if I go this route. I'm currently using 285/30/19.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
08-12-2009, 09:22 PM | #2 |
BimmerPost Supporting Vendor
1770
Rep 7,652
I dont' know for sure, if you will rub or not, but when you lower, you will get a little bit more negative camber and might actually get more clearance.
This however, does not imply that you will not rub when your shocks compress all the way in.
