07-26-2009, 12:47 PM | #1 |
8300
19
Rep 573
can a dropped car handle this?
This is the stock rear suspension at the exit of the corkscrew (laguna seca).
I have been thinking about lower springs (and possibly spacers) but after looking at this I have second thoughts. I would not want to give up performance for undeniably better looks. Any comments/suggestions? Last edited by r53s65e90; 04-12-2011 at 01:22 AM.. |
07-26-2009, 02:27 PM | #3 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
That is a bad example to use. Most cars bottom their suspensions at that point on Laguna Seca.
My e46 was slightly lowered with 550 pound springs in the rear and a huge sway bar. I still bottomed out entering 8a. Pretty much any car will be on the bump stops there. Don't worry about bottoming. What you should worry about is the detrimental effect lowering springs have on suspension geometry. If you do get lowering springs make sure they are plenty stiff to make up for the geometry changes. |
07-26-2009, 02:45 PM | #4 |
27
Rep 1,314
You also asked about spacers. In a situation like above, you sure want the tires tucked inside the fender wells. If you use the so-called, "bulldog-stance" (18mm front, 15mm rear on stock wheels), which is so popular on this forum, you will chew up a fender in that situation, even without lowering.
Most who do that are interested in cosmetics, and haven't experienced track situations such as the one you've seen at Laguna Seca.
07-27-2009, 04:28 AM | #5 | |
444
Rep 1,061
2015 F82 YMB M4 (Feb 28th ED, re-deliveried on Apr 18th) |My 2015 YMB M4 ED Journal 2008 E92 SSII M3 Coupe (Sold) | My long gone 2008 E92 SSII M3 2002 E39 SG 530i (Gone) |
07-27-2009, 07:55 AM | #7 |
Veni Vidi Vici
89
Rep 2,750
07-27-2009, 01:20 PM | #8 |
16
Rep 148
I'll be at Buttonwillow on Saturday with my Dinan springs and 18" Advan RS's all around, no spacers and no other suspension mods. I'll let folks know my experience, but I took this setup on a spirited drive yesterday through the hills near my house and no rubbing or other problems.
08-07-2009, 02:52 PM | #9 |
Supreme Allied Commander
3845
Rep 54,376
Drives: F80 M3
It's normal for the suspension to be on the bump stops coming out of the the Corkscrew.
