07-13-2009, 12:25 PM | #1 |
32
Rep 517
Car shakes when braking
Was driving on some back roads and noticed really bad shaking in the steering wheel when I brake. I was slowing down pretty hard from high speeds and now I notice shaking whenever I brake, albeit pretty subtle. I've never tracked my car and don't drive all that overly aggressive.
My car only has 8k miles so I can't imagine I would need new rotors. I have an appt to get it check out. Anyone have any idea what else it could be and If i'm gonna have to pay out of pocket?
1996 911 Carrera Cabriolet 2006 Porsche Cayman S, 2004 M3 Vert, 2008 BMW M3 Sedan, 2001 911 Turbo, 2002 Porsche 911 C4S, 2004 Cadillac CTS-V, Porsche Boxster S |
07-13-2009, 01:30 PM | #3 | |
175
Rep 298
After my first track day, I had the same "problem" you are experiencing. Do not worry since in about 2 weeks, it will go away. The vibration is caused by break pad material attached to the rotors. After a few hot laps, the temperature on the stock pads will almost melt them and if you are not careful to let your brakes cool off, you might encounter worst problems. I cant imagine you heated up your brakes so much on the streets, but try not to brake so much when stopping after reaching high speeds...it is actually better to do hard , consecutive brakes than braking for prolonged periods since this will even bring more heat to the breaks. |
07-13-2009, 01:30 PM | #4 |
Rep 95
Just a guess, but this sounds like a rotor issue that is typically caused by applying the emergency brake while the brakes are hot (e.g., complete a track session then apply emergency brake while parking). This is a common issue for people that track their cars. If you don't track your car but you do drive/brake hard, this can happen to you as well.
07-13-2009, 01:32 PM | #5 | |
Bates '08 Interlagos Launch
126
Rep 1,230
Custom Exhaust Project: Bates Valvetronic exhaust: http://www.m3post.com/forums/showthread.php?t=253661 -- Exhaust Mod pics in here: http://www.flickr.com/photos/40236795@N03/
DON'T BUY Race Ready Performance electronic cutout valves. Here's why: http://www.m3post.com/forums/showthr...40#post9589740 |
07-13-2009, 02:30 PM | #6 |
48
Rep 1,664
If you want to get them feeling better sooner, stop a few times hard from a high speed to wear off the pad material thats transferred to the rotors.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) |
07-13-2009, 04:19 PM | #7 | |
34
Rep 379
1) brake properly (short and hard) 2) buy the race pads from BMW. they are excellent but you have to get used to some squeaking... |
07-13-2009, 04:45 PM | #8 | |
96
Rep 545
Some other types of vehicles do use the rear brake pads for the parking brake. |
07-13-2009, 04:57 PM | #9 |
63
Rep 2,426
I noticed a vibration too when I braked from high speeds. That was a few months ago. It seems to have gone away by itself since then.
“For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.”
- John 3:16 |
07-13-2009, 05:18 PM | #10 | |
156
Rep 1,429
07-13-2009, 08:07 PM | #11 |
48
Rep 1,664
Yes it does, after 4 days of tracking it stayed consistant, I did a few hard stops in succession from around 80 to zero, problem solved. For aggressive track days, I agree on better track pads. Now if you warped your rotors, this technique won't work. The vibration will return quickly.
07-13-2009, 08:57 PM | #12 |
127
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
I agree that it's probably pad transfer. It took 3 weeks of street driving for it to disappear after a track weekend, but I don't use my brakes real hard in my normal day to day driving.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
07-17-2009, 08:53 AM | #13 |
32
Rep 517
Thanks everyone!! Turns out it was from driving on a bent rim, which I had replaced over a month ago. This warped the rotor, which had to be replaced, as well as a wheel hub.
07-18-2009, 07:17 AM | #14 |
Stay Ripping
60
Rep 546
Dont see how the bent rim would warp the rotor? What a crazy answer they gave you, but whatever the case glad your car is fixed.
07-18-2009, 07:28 AM | #15 |
57
Rep 1,798
I went for one track day, and had the same experience. Sent the car to the dealer, and they found that the offside disc has actually warped. They replaced both sides together with new pads.
07-18-2009, 08:29 AM | #16 |
32
Rep 517
They were kind of speculating. They never actually discussed it with me. I figured it made sense.
07-20-2009, 06:01 PM | #17 |
70
Rep 920
at least it's fixed
09 E92 M3,AW/FR. MODS:Performane Kidney Grills,Side Gills,Exhaust Tips,BMW Performance Pedals,359 Satin Black GTS Wheels,275/35/19R & 255/35/19F PSS's,Dinan Stage I Suspension,Macht Schnell Spacers 12mmF,5mmR,Rear Fogs,Euphoria 6k,LCI Tails,LUX v3,OEM IND Painted Alpine White CF Performance Spoiler, Front Splitters, and Front Reflectors,Gloss Black Hood Vents,M Performance Steering Wheel.
