07-06-2009, 03:22 PM | #1 |
257
Rep 4,048
▀▄ eas - Forge Motorsport - Adjustable Diverter Valves for N54 Turbo (135i/335i/535i)
Gentlemen,
We have a new product out on the market for you N54 Motor's. Developed specifically for BMW’s all-new N54 twin turbo motor, as found in the BMW 135,335 and 535 models, Forge Motorsport adds another replacement valve application to our already extensive vehicle specific and universal valve lineup. While virtually identical in operation to the Bosch style valves as used from the factory on many other turbocharged applications, primarily Volkswagen and Audi, BMW has utilized a very different type of valve connection mechanism that makes their product and our replacement components very unique. Starting with the world’s best selling direct replacement Bosch style valve, our own 007P piston-based design, we have revised virtually every single component of the valve body, (except the internal piston), in order to retain BMW’s unique connection mechanism yet offer improved functionality in every other possible way. The entire valve assembly is precision CNC machined from T6-6061 billet aluminum alloy on our very own Mazak CNC milling machines. Again, the valve is an aluminum piston based design, offering significantly improved reliability over the failure prone OEM diaphragm valves, yet with no change to valve response time. We utilize ultra high temperature Viton brand silicone o-rings for sealing and Mobil1 fully synthetic bearing grease for lubrication. The valves are fully tunable for both boost holding capacity and response by way of proprietary interchangeable springs and shims (washers to marginally adjust preload). By utilizing this method of valve tuning with multiple custom spring rates, the valves will retain the maximum range of piston travel and flow volume regardless of which spring rate is used. Valves with a singular spring requiring that adjustments be made by continually adding preload will suffer from decreased piston or diaphragm travel as the spring tension is increased. Though these types of valves may hold high boost levels under load, they will actually suffer from limited flow volume at throttle lift when the valve vents. The hoses included in the kit are a custom made multi-layer fabric reinforced flexible silicone hose that are designed to allow compatibility with the stock airbox and charge piping setup without any permanent modification being required to adapt our replacement valves. Even the included hose clamps are overkill. They are specifically designed for use with silicone hoses, utilizing a beveled band edge and a pressed in drive mechanism rather than perforated. They are even approved by NATO for international military use. All told, this direct replacement valve kit will be suitable for a bone stock car to one that is heavily modified. Forge Diverter Valves can be installed on the car right from the showroom floor and they will last well past having upgraded your intake, exhaust, and ECU software. They are capable of handling an infinitely wider range of boost pressure, more reliably, than the OEM valves, while carrying an unlimited lifetime warranty and money back guarantee. Forge Motorsport - Adjustable Diverter Valves for N54 Turbo (135i/335i/535i) http://www.europeanautosource.com/pr...oducts_id=2358 Models Supported: 2007+ 335i 2008+ 135i 2009+ 535i These are IN STOCK ready to ship! If you have any questions please feel free to ask on this thread, via PM, email or simply give us a call. |
07-06-2009, 04:10 PM | #2 |
Good life
130
Rep 1,937
I still don't understand what these do lol.
Current: 08 E90 M3 Alpine White Former: 11 135i Msport Space Gray -Former: 07 335i Titanium Silver E92- Former: 08 135i Alpine White E82- Past: 06 Subaru STI WRB- Past: 04 Audi S4 Imola yellow- Past:97 Honda prelude Ice blue
07-06-2009, 04:22 PM | #3 |
257
Rep 4,048
It gets tough to explain if you're not too familiar with turbo motors, but if you want an explanation on what it does send me a PM and I'll write one up for you. I don't want to create paragraphs on the thread unless it's the first post. But, please note, this is A LOT different than a Blow off Valve!
07-06-2009, 05:49 PM | #4 | |
208
Rep 2,229
07-13-2009, 07:16 PM | #7 |
14
Rep 395
Do these work with the stock charge pipe?
Any plans of selling the STETT charge pipe anytime soon? I want to upgrade my charge pipe and the diverter valves (possibly a BOV) in the near future.
LeMans 135i ///M-sport 6MT
07-13-2009, 07:33 PM | #8 | |
257
Rep 4,048
If you want to change to a BOV in the future, there's no problem with that |
07-13-2009, 09:56 PM | #10 |
23
Rep 692
08' 135 in much need of some TLC.
But after that... Watch out. AA/Berk/ER/UR/CP-e/Snow/ESS |
07-14-2009, 11:56 AM | #11 |
257
Rep 4,048
07-15-2009, 11:42 AM | #13 |
257
Rep 4,048
