07-06-2009, 01:19 PM | #1 |
81
Rep 1,210
**********s | KW Coilovers V.1/2/3 | ClubSport | AUTHORIZED DEALER
KW Coilovers, simply put, the BEST COILOVERS for the BEST CARS at the LOWEST PRICES! Are you looking to lower your BMW with the best suspension possible? Whether you are lowering just for looks or for the huge performance benefits, we have a KW system to suit your needs. Coilovers are the best suspension solution as all the parts are crafted to function together, as opposed to just lowering springs. KW coilovers are known for their signature colors, individuality, quality, and security. In addition, KW coilovers are most often the coilovers that allow the most lowering adjustability compared to other options for your vehicle. Scroll down below to read more on each Variant and decide which option is best for you! KW Variant 1 Sportive - Harmonic with KW Factory Pre-set Up Dampening The ideal systems for customers wishing to rely on the experience of KW engineers, yet determine their own degree of lowering. In extensive driving tests our engineers have set the dampers for the best balance between sporty driving, comfort and safety. [IMG]https://st15.flashecom.com/**********/images/Products/KW_Coilovers/v1logo.jpg[/IMG] [IMG]http://www.**********s.com/images/Products/KW_Coilovers/variant1.jpg[/IMG] - Optimally adjusted, sporty and comfortable dampening technology - inox-line stainless steel technology at no extra charge - Individually height adjustable - German TUEV-tested lowering range - High-quality components for long life - Comprehensive documentation for ease of us KW Variant 2 Sporty and Personalized with Adjustable Rebound Dampening The system intended for the experienced driver who requires to not only determine the individual lowering of their vehicle, but adjust the damper setting to fine tune the system to their needs. The adjustable rebound damper allows adjustment of the pitch and roll behavior of the vehicle, adapting it to one‘s own driving preferences. [IMG]https://st15.flashecom.com/**********/images/Products/KW_Coilovers/v2logo.jpg[/IMG] [IMG]http://www.**********s.com/images/Products/KW_Coilovers/variant2.jpg[/IMG] - Damping technology with individually adjustable rebound - inox-line stainless steel technology at no additional charge - Individually height adjustable - German TUEV-tested adjustment parameters - High-quality components for long life - Comprehensive documentation for ease of use - Infinitely adjustable rebound damping KW Variant 3 Race Technology for the Raod w/ Adjustable Compression Rebound Dampening The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the high speed set-up, so decisive for driving comfort, has been preset by our engineers [IMG]https://st15.flashecom.com/**********/images/Products/KW_Coilovers/v3logo.jpg[/IMG] [IMG]http://www.**********s.com/images/Products/KW_Coilovers/variant3.jpg[/IMG] - Independently adjustable damping - rebound and compression damping - inox-line stainless steel technology at no extra charge - Individual height adjustment - German TUEV-tested adjustment parameters - High-quality components for long life - Comprehensive documentation for ease of use - Infinitely adjustable rebound damping - 14- level adjustable compression damping - Unique, independently functioning damping power adjustment KW ClubSport Clubsport is getting more and more famous world-wide. Therefore, KW has decided to develop a new product line – KW Clubsport. This new product line is distinguished by motorsport applications for race track and road use with ideal performance. Nürburgring Nordschleife is the most popular race track for using our KW Clubsport suspension kits. High performance sports cars, modified saloons as well as classical sport compact cars are tuned in weight, engine and wheels for their use on several race tracks. These improvements are made for a better handling on track sport events, race taxi drives, visitor drives and equability tests particularly on the Nürburgring Nordschleife. Due to these modifications of the car some parameters are changing. Therefore, the road setups are no longer ideal for the performance of the car. For this use we offer special clubsport kits which have been adapted to the changed requirements by changing spring and shock setup as well as the installation of racing top mounts. [IMG]http://www.**********s.com/images/Products/KW_Coilovers/KW%20Clubsport%201.jpg[/IMG] - Performance set-up for the racetrack - Dampers in compression and rebound forces independently adjustable - High performance Linear race springs - Additional, available with racing top mounts - TUV approval possible depending on specification - Built on order - Model specific for each application Last edited by M II; 07-06-2009 at 01:56 PM.. |
09-09-2010, 03:29 PM | #3 |
81
Rep 1,210
Thank you for all the orders guys!
As your #1 source for KW Suspension, you can rely on **********s to help you get set up with the best suspension choice for your 1 Series! Call me today at (714) 582-3330 x 8004 and let's get you set up with the best name in the business - KW! - Eddie - |
09-13-2010, 04:24 PM | #4 |
81
Rep 1,210
09-15-2010, 07:02 PM | #5 |
81
Rep 1,210
09-17-2010, 03:14 PM | #6 |
81
Rep 1,210
09-20-2010, 10:21 AM | #7 |
81
Rep 1,210
09-22-2010, 03:42 PM | #8 |
81
Rep 1,210
