ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > Z4 DIY (Do It Yourself) Articles
  TireRack
      07-02-2009, 09:48 PM   #1
jehsautosalon
13
Drives: z4 m roadster
help how to clean speedometer.. PLS>
[IMG]<a href="http://s14.photobucket.com/albums/a323/jehsautosalon/?action=view&current=DSC02021.jpg" rel="nofollow" target="_blank"><img src="http://i14.photobucket.com/albums/a323/jehsautosalon/DSC02021.jpg" border="0" alt="Photobucket"></a>[/IMG]
As you see my fellow Z4 owners, my speedometer have some stain inside the plastic cover infront of my milleage. How do I clean this up? Any body know how to dismantle this for me to wipe it clean?
      07-02-2009, 09:52 PM   #2
jehsautosalon
13
The link
http://i14.photobucket.com/albums/a3...n/DSC02021.jpg Here is the link.. Sorry
      07-02-2009, 11:03 PM   #3
ryanchua
Z4MC Sapphire Black
Singapore
45
Drives: 570-4SL
You might want to bring that to your dealer to manage.
Sorely missed:
Zeta le Z4M Coupe (2008-2012)
BMW.SG - Singapore's Ultimate BMW Enthusiast Community
      07-03-2009, 12:29 AM   #4
jehsautosalon
13
yah
I did.. and they told me I have to change the whole thing.... I am not sure about that.. I know there is a way to open this..
      07-03-2009, 12:40 AM   #5
ryanchua
Z4MC Sapphire Black
Singapore
45
Drives: 570-4SL
And they want to charge you for it? This is a major defect and not a consumable.
See whether they can cover it for you. (they will need to talk to BMW) but squeeze your options from them.
Sorely missed:
      07-03-2009, 05:37 AM   #6
Starscream
Starscream's Avatar
United Kingdom
135
Drives: ///M Roadster + E92 335i 6MT
taking it out and apart is actually pretty easy,
You remove the entire speedo with one little bolt,
Look at the top of the speedo housing, in the middle you will see one torx bolt, T25 I think?
Remove that and then you can wiggle the speedo out,
Helps if you have the steering wheel pulled out and down, There is one or two electrical connectors in the back of the speedo, they are pretty simple to remove,
Then you need a smaller torx driver to take apart the speedo housing, somewhere between 6 and 10, Its been a while but again this isn't too hard,
I remember the plastic clips after you have removed the torx screws being harder to seperate,
Then the front of the speedo with the 2 plastic lenses your trying to clean will pull away and you can clean them
I would have loved to guide you with pictures but I don't need to take mine out so your gonna just have to figure it out with words
But its really not hard at all!
Imola Red Roadster
      07-04-2009, 05:58 PM   #7
jehsautosalon
13
Thank you so much for the reply guys.. I will try to do that!! Asap.. Thanks guys!!!
      10-09-2009, 02:38 PM   #8
david_lm
Go Ducks!
david_lm's Avatar
Drives: 06 Z4Mr
Wow, I have this EXACT problem. I figured I was the only person out there with it though.
Starscream, I'll TRY what you suggested but I sorta wanna take it to BMW and see if they'll do something about it ...
David . MY2006 IB Z4Mr
      10-11-2009, 12:40 AM   #9
david_lm
Go Ducks!
david_lm's Avatar
Drives: 06 Z4Mr
Starscream, worked like a charm!!
When you're removing the final piece that the two plastic lenses are connected to watch out for the two very small black connectors on the bottom. It took me a while to figure out what was holding the bottom of that piece to the main housing.
      10-11-2009, 12:23 PM   #10
Speedtronix714
Speedtronix714's Avatar
Drives: Ford Pinto
doesnt a dot appear next to the mileage when you disconnect the speedo??? its suppose to warn dealers or potential buyers that the speedo was disconnected and there could be mileage issues.
Hope someone can confirm this so I can clean my speedo asap.
      10-12-2009, 03:03 AM   #11
david_lm
Go Ducks!
david_lm's Avatar
Drives: 06 Z4Mr
Hmm ... I completely disconnected mine and nothing has appeared. Have to admit you have worried me a little now haha
      10-12-2009, 05:46 AM   #12
Starscream
Starscream's Avatar
United Kingdom
135
No dots as log as the same speedo goes back in
Imola Red Roadster
      10-14-2009, 11:18 AM   #13
mhughett
25
Drives: 2007 Z4 M Coupe
Agree. No problem as long as the mileage shown on the speedometer matches up exactly with the mileage that is logged elsewhere in the car's computer.
2013 Audi TT RS (Tech Pkg, Sport Exhaust, Heated Seats, Sirius)
Retired--2007 Z4 M Coupe (Imola Red/Black, Premium Pkg, Heated Seats, XM, Bimmian stubby antenna, CDV delete, Apex EC-7--Anthracite, Goodyear F1 Asymetric 2.
      10-18-2009, 07:14 PM   #14
david_lm
Go Ducks!
david_lm's Avatar
Drives: 06 Z4Mr
No dots, woo hoo!
However, I looked down the other day and noticed that the small LCD display that shows the odometer, trip meter, etc. was not lit up ... I messed with the little control next to the headlight control that sets the brightness of everything (no idea why I did this) and the display came back on. It has only done it this once (that I've seen) and hadn't noticed this before I took the speedometer/tachometer cluster out and cleaned it. Anyone?
      08-31-2010, 03:54 PM   #15
yvel26
yvel26's Avatar
7
Drives: BMW Z4 M Roadster
Nice and helpfull post. Mine is also dirty. I wonder how the stains are getting behind the glas of the speedo?
By the way what rims do you have david_lm. They look stunning.
      09-01-2010, 01:03 PM   #16
yvel26
yvel26's Avatar
7
Just cleaned my speedo.
It is indeed very easy and it looks so nice now.
Great forum.
Thanks guys!
      09-01-2010, 05:39 PM   #17
r4gs
Viper Driver
Singapore
36
Drives: F-16
this is interesting, my speedometer also has some weird pattern of stains that appear to be on the inside of the glass casing near the bottom above the mileage readout. thanks for the diy!
      09-02-2010, 09:39 PM   #18
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
i'm another victim. its been driving me crazy but i thought i would just deal with it. now that this thread was ressurected i'll see if the dealer will take care of it as i have some other issues to take care of, if not i will clean it. thanks.
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 *
'14 Jeep Grand Cherokee Overland Hemi... No more snow for the M!
      09-03-2010, 09:02 AM   #19
SHEEDI
Drives: 2009 335i - Sport PKG
2009 BMW 335i  [8.50]
i have then same issue,dirty speedometer inside. can somebody please post DIY with pictures please? that will be great help
      09-03-2010, 02:53 PM   #20
yvel26
yvel26's Avatar
7
Just follow the directions, it is really very very easy.
I did it a few days ago.
The stains were really annoying me and now it looks like new.
Very very pleased with the result!
      09-06-2010, 04:42 PM   #21
SHEEDI
Wow, i cleaned my speedometer today, no dots, it looks like brand new Thanks all of you for help.
      10-28-2010, 10:27 PM   #22
BettyBmw03
Drives: 03 Bmw Z4 2.5i
Did this as well, easy and straight forward...thanks
zpost
