07-02-2009, 03:44 PM | #1 |
1291
Rep 7,389
Dinan Lower Control Arm Monoball Kit
Anyone tried these on an E9x M3 yet?
I'm interested in a noise and performance report from an end user. Dave
07-02-2009, 05:09 PM | #2 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
Been on mine for about a week. Very slight increase in NVH (noise, vibration, harshness). Some noise at low speeds, with no change in vibration or harshness. Under normal driving I feel no difference. I expect the car to feel much better under braking on the track, where deflection will be all but eliminated.
07-04-2009, 07:47 AM | #3 |
374
Rep 8,033
RJ, can you feel any differences in steering feel/precision under heavy cornering? I guess you might not have been able to test that on the street though...
07-09-2009, 06:06 PM | #5 |
70
Rep 920
sorry, what exactly does this do
09 E92 M3,AW/FR. MODS:Performane Kidney Grills,Side Gills,Exhaust Tips,BMW Performance Pedals,359 Satin Black GTS Wheels,275/35/19R & 255/35/19F PSS's,Dinan Stage I Suspension,Macht Schnell Spacers 12mmF,5mmR,Rear Fogs,Euphoria 6k,LCI Tails,LUX v3,OEM IND Painted Alpine White CF Performance Spoiler, Front Splitters, and Front Reflectors,Gloss Black Hood Vents,M Performance Steering Wheel.
07-13-2009, 03:09 PM | #6 |
Veni Vidi Vici
89
Rep 2,750
07-20-2009, 05:58 PM | #7 |
70
Rep 920
thanks radiation joe. this site is awesome. thanks forum members.
07-22-2009, 01:49 PM | #8 |
169
Rep 3,831
How long is the install, and is in complicated? Im guessing you don't need an alignment afterwards right?
Should be a good mod for ppl who track or auto-x.
07-22-2009, 11:43 PM | #9 | |
98
Rep 1,043
i feel the flex in the front.. but never knew exactly what it was...
07-23-2009, 06:02 AM | #10 |
Veni Vidi Vici
89
Rep 2,750
Yes. I think it's worth it. Like I said, I don't feel any significant difference on the street, but I'll have it on the track soon enough. I expect the car to feel much better under braking on the track with these control arm bearings.
10-25-2010, 10:22 PM | #12 | |
Moderator
673
Rep 4,737
The Dinan Monoball Kit replaces the stock rubber bushings in the rear trailing arms with racing-quality spherical bearings and precision machined aluminum housings, improving response by eliminating the deflection associated with the stock bushings. The bearings are Teflon-lined for and offer superior load capacity to the other tuner's products. |
10-25-2010, 11:08 PM | #14 | |
80
Rep 961
Even Steve's video argues that to settle the rear end you need the adjustable camber links. What's interesting about the rear camber links is that both ends of the curved factory link are actually ball joints, not bushings. Must be a lot of force at work if they bend... |
10-25-2010, 11:24 PM | #15 | |
Moderator
673
Rep 4,737
About the toe links, Dinan's adjustable ones are definitely easy to use when you set up your car, but less deflection? I call marketing BS. |
10-25-2010, 11:41 PM | #17 |
Moderator
673
Rep 4,737
This is way too funny. Sometimes it makes you wonder about the quality of the products if they cannot even get a web site right.
Here's a pictures of the M3 front tension rod. The picture on Dinan's web site doesn't seem to resemble the shape of the stock bushing at all... |
10-26-2010, 11:52 AM | #18 |
Rep 53
When they say rear trailing arms they're talking about the rear lower on the front suspension... as there are two lower link arms on each side of the front suspension...
10-26-2010, 12:19 PM | #19 | |
Veni Vidi Vici
89
Rep 2,750
The monoballs were originally designed for the rear trailing arms on e46 cars. Then Dinan discovered that they cured several problems in the front ends of the e60s. Now they sell them for the tension rods in the front suspension of the e9x cars. Looks like Dinan just redesigned their website. They pulled the wrong description for the e9x monoballs.
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now. Why, yes. I am an abrasive bastard. |
08-26-2015, 02:57 PM | #21 |
Bob Saget
355
Rep 2,229
08-26-2015, 07:44 PM | #22 |
433
Rep 1,286
This is the Bimmerworld version, it's a bit more cost effective.
http://store.bimmerworld.com/bimmerw...kit-p1860.aspx Same thing (for the front). I've had this for at least 25,000 miles now and multiple track events. No issues, no problems and doesn't need any maintenance. |
