06-24-2009, 05:36 AM | #1 |
414 little horsies
56
Rep 405
My brakes feel weaker
i have 14,000 miles on the stock rotors and for the few thousand miles my brakes seem to feel much weaker
i have to push my foot way down, i took it to the dealer and 2 people inspected it and said that my brakes are at 50% I think there might be something wrong when i first got the car, when i touched the pedal the car would stop, now i have to push the break 3 inches down for the car to stop
Race Precision Inc
06-24-2009, 06:22 AM | #2 |
72
Rep 1,171
I dont have that experience after 22,000km (which include 3 track days on stock brakes). Mine seem perfectly fine. During the track days I did not push the brakes to their absolute limits for too many turns (didn't want to end up with wrapped rotors) but I was giving them some hard time. Still no adverse chance in braking performance.
How did the dealer justify the 50% reduction? (I guess you mean 50% reduction in the pad thickness - not in braking performance). |
06-24-2009, 06:40 AM | #3 |
414 little horsies
56
Rep 405
i drive my car hard, and i really do not like the feel of the brakes as of this past couple thousand miles
they said it was a 50% reduction in pad thickness im going to really complain until they fix it some how
Race Precision Inc
06-24-2009, 09:06 AM | #4 |
I can't belive this car is a 4 door family sedan.
66
Rep 385
brake feel is going to change through out a pads life. If you look at a brand new factory brake pad, the pads face actually gets larger as it wears down. This gives you a more gradual feel or a less touchy brake pedal..... When a pad is brand new, the caliper piston pushes down on a smaller amount of pad material which increase brake pressure or torque. As the brake pad wears down, more surface area of the pad is touching the rotor which causes the pressure to be divided over a larger area. This causes the need for more pedal effort to produce the same amount of braking. Does all that make sense? Im kinda scatter brained ATM
06-24-2009, 09:59 AM | #5 |
I like cars
329
Rep 5,052
Maybe bleeding them and replacing the fluid will help. It's best you pay someone to do that if you're not mechanical, though. If you get air in the lines you'll make things worse.
06-24-2009, 10:16 AM | #6 |
258
Rep 5,012
Other than having less fluid in the reservoir (to compensate for worn pads), brake feel should NOT change as pads wear.
I'd suggest a bleed job. Your symptoms are typical of air in the brake lines, which means your fluid boiled at some point (if nothing else is wrong). That should fix your problem. Good luck. |
06-24-2009, 10:51 AM | #7 | |
Moderator
94
Rep 1,920
Pedal TRAVEL should NOT change over the life of the pad. Pedal FEEL (feedback, etc. is what I am refering to) MAY change over the life of the pad, although usually not the case. If your travel is increased, you either have air in the line or a failing master cylinder......bascially, it must be one of those two things. Well, you could have a hole (leak) in the system...but that is highly unlikely. You would continue to loose fluid, and that would be evident by observing the fluid level over time. As the pads wear, the fluid level will go down to compensate for the difference in system volume, but if you did have a leak, the level would drop very quickly. I really doubt it is a leak, but I guess it is the other, although highly unlikely, alternative. Bleed the fluid. It should make the difference. I would bet that is the issue. An easy way to check the master cylinder is to: Start car Leave in park Press brake pedal as hard as you can and hold it down If you feel the pedal sink more (SLOWLY), the master cylinder is bad If the pedal remains rock solid, it is ok.
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket 2014 F30 328i -- Kids car 2008 E90 M3 -- Sold 2004 GT3 -- Sold 1997 M3/4 -- Sold 1995 M3 -- Sold |
06-24-2009, 05:15 PM | #8 |
414 little horsies
56
Rep 405
thanks guys, how does one bleed there breaks and replace fluid
im probrably going to take it to a mechanic, any suggestions on how i could do it myself?
Race Precision Inc
06-24-2009, 05:27 PM | #9 |
70
Rep 920
i wouldn't even attempt to do that yourself if you are asking for tips on how to do it. play it safe and take it in.
09 E92 M3,AW/FR. MODS:Performane Kidney Grills,Side Gills,Exhaust Tips,BMW Performance Pedals,359 Satin Black GTS Wheels,275/35/19R & 255/35/19F PSS's,Dinan Stage I Suspension,Macht Schnell Spacers 12mmF,5mmR,Rear Fogs,Euphoria 6k,LCI Tails,LUX v3,OEM IND Painted Alpine White CF Performance Spoiler, Front Splitters, and Front Reflectors,Gloss Black Hood Vents,M Performance Steering Wheel.
06-25-2009, 09:31 AM | #10 |
Moderator
94
Rep 1,920
Roger that. Just take it to a mechanic and have them do it.
06-25-2009, 10:12 AM | #11 |
48
Rep 1,664
Go get a brake fluid flush... Air in your brake lines can effect pedal feel. Wear on the pads should not change the distance pedal travels.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) |
06-25-2009, 10:36 AM | #12 |
Bates '08 Interlagos Launch
126
Rep 1,230
On my z06, I had this problem even after a bleed. I turned out to be air in the abs solenoid. To clear the air I activated ABS a few times with some very hard stops (hard enough to enable abs and "pump" the air out). I dont know if the M3 braking system is similar, but it certainly cant hurt to try. Worked for me.. I had a tight pedal after that.
Custom Exhaust Project: Bates Valvetronic exhaust: http://www.m3post.com/forums/showthread.php?t=253661 -- Exhaust Mod pics in here: http://www.flickr.com/photos/40236795@N03/
DON'T BUY Race Ready Performance electronic cutout valves. Here's why: http://www.m3post.com/forums/showthr...40#post9589740 |
06-25-2009, 11:18 AM | #13 |
414 little horsies
56
Rep 405
thanks guys, im going to bleed my breaks
btw do u guys know if the master cylinder in the break pads are bad and need to be replaced, I followed GT3 Tim's advice and i felt the pedal sink a little bit in slowly
Race Precision Inc
06-25-2009, 11:32 AM | #14 | |
258
Rep 5,012
And yes, doing a bleed job is fairly easy, but don't recommend learning on the M3 by yourself. Best way to learn is to offer your house for a 'tech day', and do the brake bleed with other owners who have done it before. This is a very common practice with motorcycles, and a great way to learn, and at the same time have a good time. Take care. |
06-25-2009, 07:28 PM | #15 |
48
Rep 1,664
Few DIY posts on the e90post.com tech sections. Take a look and see if it would be something you would even like to try.
