BMW M3 Forum (E90 E92)
      06-15-2009, 12:44 PM   #1
anthony @ eas
BimmerPost Supporting Vendor
anthony @ eas's Avatar
Drives: R56 Cooper S
▀▄ eas | Macht Schnell Competition Wheel Spacers DIY Instructions
There's a bit more to installing spacers than yanking the wheels off and sandwiching them between the wheels. Here's how to determine what kit is needed.
The outermost point of your tire/wheel combo will be at the outermost "bulge" of your tire's sidewall. Using a straightedge or ruler flush with both the top and bottom of the tire - measure the clearance from the outer face of the tire to the inner lip of your fender and record the results onto paper for later.
In this picture, we can gauge the clearance using a tape measure (straightedge not shown):
Next, begin by jacking up the vehicle and securing with jackstands. Remove wheel and clean hub of all dirt and/or surface rush with a wire wheel to ensure a clean and flush mounting surface, eliminating the chance of vibration:
A small amount of anti-sieze on the hub lip will make spacer removal easier if needed:
Macht Schnell spacer mounted to front wheel, ready for wheel mounting:
Extended lugs must be used and are included with all Macht Schnell spacer kits. Secure wheel with new fasteners and torque to 85-90ft lbs, reinspecting after 50 miles.
      06-15-2009, 07:09 PM   #2
chris s
chris s's Avatar
1250
Drives: 2022 Dravit G80 M3
Can you specify what type of anti-seize was used?
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD
2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten!
2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD!
      06-15-2009, 07:25 PM   #3
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Any type can be used - the specific brand used in our DIY was from Loctite.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      06-18-2009, 05:22 PM   #4
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
can you guys show us how to remove spacers ? It was very easy for me to install them ( just the way you described it) but it took me 2h to remove just the rear spacers ... it was like a nightmare ...
      06-18-2009, 06:39 PM   #5
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Was the anti-seize used during installation?
      06-18-2009, 08:00 PM   #6
doba_s
doba_s's Avatar
yes, the same one you guys are using ...
      06-19-2009, 06:51 PM   #7
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
With anti-seize, removal should be a snap. A slight amount of pressure with a pry bar will unseat the spacers.
      06-20-2009, 10:32 AM   #8
doba_s
doba_s's Avatar
that was my plan, but there is no space to put the pry bar in between
      06-20-2009, 10:10 PM   #9
GregW / Oregon
Commander-In-Chief
2122
Should have got REs! Seriously, get a tapered chisel and strike it at the joint. Should pop them off. A wood chisel would be best because of the acute angle tip.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      06-21-2009, 07:31 PM   #10
Kev
Critical Care Anesthesiologist
Kev's Avatar
Hong Kong
481
Drives: SMB F83
That was one of the reasons why I bought the RE spacers for my NEEZ wheels.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist"
      06-21-2009, 07:50 PM   #11
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Gentlemen, the MS Spacers also have chamfered edges like other respected brands.
As stated earlier, a slight amount of pressure with a pry bar will unseat the spacers - good prepping and a small amount of anti-seize on the hub surface will all easier removal if needed.
      06-24-2009, 12:20 AM   #12
doba_s
doba_s's Avatar
I had H&R and after it took me 2h I said ... f..k it ...
      06-24-2009, 11:48 AM   #13
anthony @ eas
Pics of said chamfered edges:
      08-27-2009, 06:13 PM   #14
Dr.G
Dr.G's Avatar
Drives: Not enough room!!!
cool thx a lot!
      08-27-2009, 08:58 PM   #15
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
why are you guys taking off the spacers? sick of them?
      08-27-2009, 09:32 PM   #16
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Who's removing them? We've been installing them almost every day on almost every M3 rolling through the doors.
      08-27-2009, 09:49 PM   #17
GregW / Oregon
Commander-In-Chief
2122
Don't weld them on next time!
      02-28-2011, 12:41 PM   #18
mr_yogi
Drives: Success
Do spacers affect warranty in any way? I heard that a lot of tire/wheel shops won't touch your car if you have spacers on. Is this true?
      02-28-2011, 03:01 PM   #19
GregW / Oregon
Commander-In-Chief
2122
Any mod you do to your car could affect warranty, but its a long shot with spacers. Only thing I could see being blamed on them is increased wheel bearing wear. Individual tire shops may have a policy due to assumed liability related to poor fitting spacers. High quality hubcentric spacers do not typically cause issues, though I wouldn't go more than 10-12 mm max.
      03-01-2011, 05:44 PM   #20
mr_yogi
Drives: Success
Thanks Greg! A popular fitment I've seen on the boards is 15/12. Do you think that's too much then?
      03-01-2011, 06:33 PM   #21
GregW / Oregon
Commander-In-Chief
2122
Spacers
No, 15 vs. 12 is only 1/8" difference. I went 12/12 with my stock wheels and I thought it looke fine.
      10-13-2011, 06:55 PM   #22
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Thread revival - had a few questions on procedures!
m3post
