06-14-2009, 12:05 AM | #1 |
415
Rep 2,475
Rogue Engineering E9X M3 Rear Toe Arms
2020 /// M2 Competition
Past: 2016 435i ZHP Edition | 2013 335i | 2011 135i | 2008 328i | 2006 325i |
06-14-2009, 11:30 AM | #3 |
Commander-In-Chief
2122
Rep 8,924
06-14-2009, 02:36 PM | #4 |
415
Rep 2,475
My close friend has these on his E46 M3. It was one of the best mods he did. If you're a track junky, or just have your M slammed on coil-overs...these will come in handy...big time. Basically helps dial out toe, so you don't wear the inside of your rear tires so fast.
Like Greg said, click the link.
06-14-2009, 04:28 PM | #5 | |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
06-14-2009, 04:35 PM | #6 | |
Commander-In-Chief
2122
Rep 8,924
http://www.ground-control-store.com/...ion.php/II=699
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 Last edited by GregW / Oregon; 06-14-2009 at 05:54 PM.. |
06-14-2009, 04:42 PM | #7 | |
415
Rep 2,475
http://www.rogueengineering.com/Merc...y_Code=CTRLARM
06-14-2009, 09:54 PM | #8 | |
Veni Vidi Vici
89
Rep 2,750
None of those arms make a very significant difference with the e46. Replacing the rubber trailing arm bushings with spherical bearings was a very good mod, though. |
06-24-2009, 01:48 AM | #10 |
Supreme Allied Commander
3845
Rep 54,376
Drives: F80 M3
Let's hope the rod ends stay quiet at least for a few months!
Have a look at these beauties we made for the 135/335i using oem sealed bearings, these should outlast the car! |
06-24-2009, 06:14 AM | #11 |
yodog
197
Rep 5,025
Will this improve the handling combined with a low drop from coilovers? Or does this only help tire wear? Would the front need new toe arms?
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
06-24-2009, 06:44 AM | #12 | |
37
Rep 390
If the rear has too much toe, it could create an undesired ammount of understeer. The front does not need those arms, toe is adjusted from the tie-rods. |
06-24-2009, 09:37 AM | #13 | |
Moderator
94
Rep 1,920
I had to get RTC arms on the GT3 as after the ride height was adjusted, corner balanced, and aligned how I wanted it, I could not get the rear toe where I wanted it. Thus, I had to get a set so I had the adjustability. After that, the rear felt rock solid under heavy cornering loads. A definate fringe benefit! Before, with OEM RTC arms, the rear felt a little skiddish at the limit. If you guys track, I would recommend these. RE makes some kick ass products.
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket 2014 F30 328i -- Kids car 2008 E90 M3 -- Sold 2004 GT3 -- Sold 1997 M3/4 -- Sold 1995 M3 -- Sold |
06-24-2009, 10:44 AM | #14 | |
3845
Rep 54,376
Drives: F80 M3
06-30-2009, 07:01 AM | #15 |
yodog
197
Rep 5,025
So you're saying these RE Rear Toe Arms won't last as long as the stock setup? How long you expect these to last?
06-30-2009, 06:08 PM | #16 |
3845
Rep 54,376
Drives: F80 M3
