05-14-2009, 11:16 AM | #1 |
61
Rep 615
FMIC from X6 35i?
I was just checking the FMIC's, and it sucked I couldnt find a cheap one with good quality here in germany.
So I thought....whats up with the N54 engine in the X6. That car is so heavy, imagine the heatsoak if you do a few accelerations. So, fact is, price is 190Euro (~200$) It looks the same (exept bigger) Stock mounting. 135i FMIC X6 35i FMIC Man, 200$, thats nothing. Im gonna order this part and check it.
f*ckin' love my car <3
05-14-2009, 01:22 PM | #3 |
76
Rep 5,970
I'd be surprised if it will fit without a lot of fabrication. I doubt the width is the same, and there's not a lot of movement available in the pipes to match them to the inlet and outlet couplings on the intercooler.
05-16-2009, 02:58 PM | #5 |
508
Rep 929
Matt,
did some quick measurements using a tape measure and converted to metric, these are not exact but the 135i intercooler is dimensionally smaller the the one pictured. overall width approx.71.1 cm (outside flanges of plastic inlets) intercooler width approx 52.7 cm depth (front to back) 11.1 cm (about the same as the one pictured) probably is on 11cm height approx. 13.2 cm The overall width maybe the same if you measured in a different spot. The plastic end pieces on the 135i seem to be wider then on the X6, so it appears it may fit, it is not hugely larger so may work, its an easy R&R, go for it. Fran |
05-16-2009, 03:09 PM | #6 | |
61
Rep 615
Thanks man, for 200$ you cant got wrong.
05-23-2009, 02:20 PM | #9 |
20
Rep 354
Keep us informed plzzz
2009 AW 135i
CP-E CATLESS DPS, AFE EXHAUST , OIL COOLER KIT,FORGE DVV,,BMW PERFORMANCE SIDE SKIRTS AND BMW P . PEDALS, BMW PERFORMANCE SPOILER , BMW PERFOMANCE KIDNEY GRILLS, CODE 3 IC, DIREZZA Z1 STAR SPEC |
05-23-2009, 06:14 PM | #13 |
2173
Rep 2,357
You are the man...
BSM ///M2cs, 6spd
08-17-2009, 01:42 PM | #15 |
50
Rep 657
bump?
-135i BSM, CRBL ,custom front lip/Indianapolis red fade, blacked out tail lights/corner headlights, golf tee, BMS Air intake, SSTT, CF spoiler,Powdered coated OEM rims gunmetal high gloss,custom Rear diffuser Black/Indianapolis red fade |
08-17-2009, 07:08 PM | #18 |
59
Rep 1,859
so it does fit? and the benefits are what vs an aftermarket option?
E82 N54 6MT 6FL 668 KASW turned in
E92 Crimson/Cream N54 6MT, ZSP, ZPP, ZCW, Nav, Sat radio, HD Radio, Logic7, PDC, Active Steering, Active Cruise, 6FL, CA |
08-18-2009, 11:59 PM | #19 |
US Air Force
Rep 21
Three Questions:
What are the exact part numbers for the parts? (Since I'm deployed right now and can't access the links) Is there any cutting involved? Do you need to take the bumper off to install it? Thanks |
08-19-2009, 11:54 AM | #21 |
59
Rep 1,859
Probably yes, but if it came to it I think even BMW wouldn't argue in court that a larger intercooler made by them for the same exact engine and meant to keep it cooler under the higher stress of a heavier vehicle application is what caused damage to the same engine it is meant for in a car subjected to lower stress by virtue of its smaller mass, but who knows
