BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      04-20-2009, 11:29 AM   #1
BimmerRob08
BimmerRob08's Avatar
Drives: 2008 M3, Space Gray
Best recommended spacers with 18" no spring drop?
Trying to do my homework here and am interested in spaces. So far my ride is stock with 18" wheels. What does everyone recommend for the best spacer option (not too extream) with stock springs? I may go with H&R springs down the road at a later date. Do spacers add a real benefit to the ride? Will they cause stress on the bearings also? Which is the best spacer set up as far as size, Front/Rear, manufacture of spacers? Thanks,
      04-20-2009, 03:01 PM   #2
SV Concepts
SV Concepts's Avatar
Drives: Vorsteiner E60 M5
Location: 1460 White Oaks Rd. Suite F. Campbell, CA 95008
They help the handling a teeeenie tiny bit by widening your stance, but the difference is so negligible it's like having a case of water in the car versus not
Your best option is always to measure how much room you have before the fender and allow 1mm of space for when you have passengers. I'd say that's probably 5mm front and 5-10mm rear TOPS.
Also, go with H&R spacers, never had a complaint!
JL
      04-20-2009, 03:15 PM   #3
kmarei
kmarei's Avatar
Egypt
687
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
JL
if only 5mm in the front
how can all these people be installing the VMR CSL replicas?
i have a set of 18" (soon to be installed) and the offset for the front is 20
which is 9mm further out than the stock ET29
so that is outside the 5mm limit you said was ok
      04-20-2009, 03:43 PM   #4
SV Concepts
D'oh I read 18's and thought it was a 335i
For the M3, I believe most people get 10mm front and 12-15mm rear, we sell that package all day long. Some people even buy 12mm front and 15m rear.
You should still measure, though.
      04-20-2009, 04:19 PM   #5
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
isnt it the other way around 15 front and 12 rear?
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      04-20-2009, 04:37 PM   #6
SV Concepts
You know, you're probably right. All I see is that they order 15mm and 12mm.
I need to get some rest, been working too hard and I'm losing my edge
      04-20-2009, 06:50 PM   #7
BimmerRob08
Thanks fella's, I've read where like 20mm goes in the front, 15mm in the back. Not sure why people are doing that. Maybe it's required. We should research this a bit more. I'm curious as I might opt for it. J, get some sleep
      04-20-2009, 07:02 PM   #8
busman76
busman76's Avatar
10
Drives: E90 M3 AW/Fox
I am presuming because the tire is wider in the rear than the front thats what it would take to make front and back tires look flush against the fender.
08 E90 M3 AW/FR/ 6 speed/Prem/H&R/Macht Schnell Air Filter/B&W Roundels/ Monochrome Badging/ Black Kidneys/ black grilles/ clutch pedal spring removed,painted reflectors,AA Pulley.
On order: Macht Schnell Spacers 15/12, GP Thunders,
      04-21-2009, 04:15 PM   #9
BimmerRob08
That's a possible reason. Interesting
      04-21-2009, 04:19 PM   #10
SlammedR8
SlammedR8's Avatar
521
Drives: 2019 X5 40i/2020 R8 V10 Spyder
I'd go with H&R
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather
2020 Range Rover HSE - Black/Black
2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black
      04-21-2009, 04:52 PM   #11
GTM
GTM's Avatar
Drives: E92 M3
You also have to understand that...
More you pull out the wheel, more wheel gap is pronounced.
We usually do not recommend wheel spacers unless you have decent ride height because those spacers will make wheel gap bigger than what it is...
      04-22-2009, 06:36 PM   #12
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
15 front, 12 rear looks best. If you want that really wide look, go 15mm in the rear but I think it looks a bit funky.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle
Special Thanks: Gintani | OETuning | eAs
      04-23-2009, 10:24 AM   #13
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
i thought most people did this mod for the exact opposite reason to close the gap not make it bigger?
m3post
