BMW M3 Forum (E90 E92)
Mporium BMW
      03-30-2009, 10:18 PM   #1
TRZ06
TRZ06's Avatar
Drives: 16' M3
EDC question
Ok, so after reading all threads about the EDC, the consensus is that it is only in "active mode" when in comfort or normal mode, and is "passive or non-active in sport mode.
Where does this info. come from? No where in the manual does it say that the EDC is disabled/passive when in sport mode. If you look at page #84 it basically says.....
Comfort: Select comfort if you want comfort-oriented shock absorbers
Normal: Select normal if you want a balance between comfort and sportiness
Sport: If you want consistently sporty control of the shock absorbers.
But nowhere does it say that the active portion of EDC is inactive in sport mode.
If fact it starts out by saying "You can select from 3 different programs for EDC"
Anyways, I still thing that the shocks make tiny adjustments even in sport mode.
Comments?
18? Camaro 2SS 1LE
16' M3 MG Ext. /SO Int. (DCT, Ohlin R/T, 19" wheels)
15' Audi S4
13' Audi TTRS (APR stage 1, MSS springs)
09' C6 Z06
08' M3 Interlagos Blue: 6sp, Tech.
      03-30-2009, 10:46 PM   #2
Ronin13
Ronin13's Avatar
Drives: E92 M3, RRS Supercharged, S2K
Probably more references out there. See third response from Larry Koch on normal vs. sport.
http://www.m3post.com/forums/showthread.php?t=134860
      03-30-2009, 10:50 PM   #3
dcstep
Drives: '09 Cpe Silverstone FR 6MT
2009 M3  [8.40]
The usefulness of Sport will depend on the course. If it's smooth, then you'll get quicker transitions and less body roll. The Normal mode is best for rough roads at speed and courses with choppy corners or braking areas. By staying active, it'll give you more control as you need it. Comfort is best for drag starts from a dead stop, since it'll allow the most weight transfer to the rear wheels.
I don't know why you say the adjustments are "tiny." I've driven with passive adjustable Konis, Bilsteins and Tokikos and the EDC has more adjustment range than any of those. Generally all of those "performance" shocks stayed way harder than the EDC, even on their softest settings.
Have you been through a fast right-left transition with a dip or bump in the middle? I've never had a car that would track so well. My prior "great handling" cars would fly over the bump and my comfortable cars would perhaps track the bump, but bound out all over the place on the other side. The BMW keeps the drama so low that you think that nothing's going on, when a lot is really going on.
Dave
      03-31-2009, 12:48 AM   #4
TRZ06
TRZ06's Avatar
Drives: 16' M3
Dave
Tiny was used very loosely in my statement. I am by no means belittling the EDC system, I KNOW it is awesome as I had KWV2 on my 335I, my comment was whether the system goes into a "passive" mode in the SPORT setting. Most say yes, but the manual says nothing about it being passive at all. The manual suggests that all 3 modes are active modes.
Passive meaning not making adjustments on the fly and just being a regular preset damping.
18? Camaro 2SS 1LE
15' Audi S4
09' C6 Z06
      03-31-2009, 10:40 AM   #5
lucid
lucid's Avatar
Drives: E30 M3; Expedition
I don't see how the manual suggest all 3 modes are active modes. If anything, it suggests otherwise; note the use of the term "consistently" for sport mode. Details of how the suspension settings work were a part of the original press releases I think. There was a 60 page word document, and they might be in there. Also, Ronin13 posted the link to Larry Koch's answer to that specific question. One must assume he answered that question correctly.
      03-31-2009, 10:44 AM   #6
southlight
Moderator / European Editor
southlight's Avatar
1537
Drives: X3M
Absolutely, Sport mode is passive and set at 75% of maximum damping.
I'm kinda lazy on that one. Do you really need proof?
Best regards, south
Those forums...WHY NOT?
JOIN THE 6MT CLUB GROUP
m3post
