KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
03-25-2009, 02:28 PM | #1 |
235
Rep 1,334
20" BBS LM-R from [GT Motoring] :Agressive Spec:
Ordered these 8 weeks ago along with my KW Clubsports which arrived much earlier. The wheels were shipped from Japan. GT Motoring balanced/mounted Yokohama Advan Sports for me with TPMs and shipped them to me. They are spotless. Again I have to thank Jae over at GT Motoring for all of his help. He's very knowledgeable, was always there to answer my questions, courteous, and updated me on the progress of my order. He also threw in a couple of extras .
So here they are 20x9 et8 fronts with 255/30/20 tires. 20x10 et18 with 285/30/20 rears. If you saw my car before with just the Clubsports, you saw it was pretty dumped. There was major rubbing with it that way. I raised it about 1/2 inch all around and now there's some rubbing on the right rear which I hope some camber will be able to fix. The fronts clear the fender fine but there is some rubbing on the fender well liner close to full turn. Here are some quick pictures to show what the car looks like at different angles. I'll take some better photos later and post them in the photos section. On with the show. Fresh off Fed Ex truck Washed the wheels and applied a layer of Jetseal 109 (sealant) Last edited by sard; 03-25-2009 at 09:34 PM.. |
03-25-2009, 02:40 PM | #3 |
1251
Rep 6,913
Wow...thats hot!
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
03-25-2009, 02:53 PM | #4 |
LTBMW
106
Rep 1,068
Drives: 2008 AW e92 M3
i wanna hump your car all day long! looks sick!
tuned by LTBMW
03-25-2009, 03:11 PM | #8 |
235
Rep 1,334
No spacers. I'm sure the rear rubbing will be fixed with some camber adjustment on the rear. Not sure about the front wheels rubbing on the inside fender well liner though.
03-25-2009, 03:13 PM | #9 |
509
Rep 1,570
Drives: 2013 LRP M3 Coupe
beautiful!!!
03-25-2009, 03:15 PM | #10 |
22
Rep 490
Beautiful.
Very surprised about the rubbing. Your running an aggressive offset, but other are running even more aggressive with no rubbing. I wonder if it has anything to do with the KW's. Is it rubbing on the fender or the suspenpension?? My new wheels are 20x11.5 and running a 325 on the rear with no rubbing.
2008 E93 M3 6MT, White/Bamboo SOLD!!!
2011 F10 550i Sold 2012 750Li Sold 2013 M5 6 speed |
03-25-2009, 03:25 PM | #13 | |
235
Rep 1,334
03-25-2009, 03:28 PM | #14 | |
56
Rep 1,804
The wheels look sick! Not to hijack the thread but Hi Volinder, Can you post a link of the pics of your wheels? and also post exact specs on the tires? |
03-25-2009, 03:40 PM | #16 | |
191
Rep 2,867
U just have to decide tho wether ur fine with paying a shit load of money on custom wheels and b cool with them rubbing. I wasnt, therefore took the spacers off. |
03-25-2009, 04:03 PM | #18 |
68
Rep 1,034
Perfect ride height, Perfect offset, Perfect car!
Because you have not adjust any alignment since you lowered the car, the rears are rubbing unevenly. Once you get the little more camber front and rear, you won't have any rubbing issue. Anyways, car looks VERY HOT, I wish I should have ordered another set for MY M3. |
03-25-2009, 04:09 PM | #19 | |
191
Rep 2,867
03-25-2009, 04:21 PM | #20 | |
68
Rep 1,034
FYI, this set up has been done already. We would NEVER recommend such a set up if the wheel will have major rubbing issue. Rear rubbing issue can be solve with just stock camber adjustment knob. It is NOT even near "serious" negative camber, just little more camber than stock config. For fronts... Because we knew stock front suspension wont allow enough camber to clear the fronts, this is why we recommended KW ClubSports to give extra camber to go with this wheel. We do NOT sell this wheel to those who will be lowering the car with just springs or basic coilover due to rubbing issue. The above pictures are NOT even at max neg camber YET, there are PLENTLY room for adjustment. And even at current setup, Sard says it does NOT rub as he stated on first thread. The rubbing with fender liner while turning is different issue. |
03-25-2009, 04:29 PM | #22 |
444
Rep 1,061
Thats hot!!
2015 F82 YMB M4 (Feb 28th ED, re-deliveried on Apr 18th) |My 2015 YMB M4 ED Journal 2008 E92 SSII M3 Coupe (Sold) | My long gone 2008 E92 SSII M3 2002 E39 SG 530i (Gone) |
