      03-19-2009, 05:38 AM   #1
Citizen Z
Alpine Master
Citizen Z's Avatar
Drives: '08 135i AW Sport
How long to install catted downpipes?
I have catted downpipes arriving this week and need to know how much time I need to budget for the install. I will have a lift avialable with every tool conceivable at my disposal since I can use the auto crafts shop on post (Army). I just need to know how long it'll take. I'm very mechanically inclined.
Alpine White with Taupe Leather 135i, Sports Package, Heated Seats, Comfort Access, iPod Adapter
Fastness: http://www.1addicts.com/forums/showthread.php?t=252727
      03-19-2009, 09:38 AM   #2
Citizen Z
Alpine Master
Citizen Z's Avatar
Nobody knows? Nobody has EVER installed catted downpipes?
      03-19-2009, 11:03 AM   #3
My135
85
Drives:
Which down pipes that you have, Cp-e, RR or AR?
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
      03-19-2009, 11:06 AM   #4
Citizen Z
Alpine Master
Citizen Z's Avatar
cPe catted with cast bellmouths. The install process should be identical for nearly all the dowpipes, the only difference whether or not you have to fuss with the o2 sims.
      03-19-2009, 11:58 AM   #5
KeithLM
Proud 1er
KeithLM's Avatar
24
Drives: Crimson/Coral 135i
My BMW shop charges it as a 4.5 hour job. It can be tricky the first few times I'm told. You have to kind of angle them in their brackets just so. Make sure you keep track of which O2 sensors go where and keep count of all the bolts and screws.
      03-19-2009, 02:23 PM   #6
imdanomite
likes boobies ( o )( o )
13
Drives: 2009 BMW 135i
^^^i've done a couple, it's just a little tricky moving the pipes around. the v-band clamps can be a little annoying.
support the engine with a jack stand, unbolt the cat from the exhaust (you don't have to remove the exhaust, just let them hang). mark all the o2 sensors/connectors. there is a bracket holding the lower portion of the cats (connected to the trans bell housing). remove o2 sensors, loosen up the v-band clamps all the way, remove right side motor mount bracket (entire assembly). rest is just twisting and pulling till they fall out.
      03-19-2009, 02:24 PM   #7
TT1351
TT1351's Avatar
508
Drives: 135, GTS, E30 M3+
Not that long if all goes well. The problem I had was getting the clamps back on the the new down pipes and exhaust manifolds, pay close attention to how they were situated before removal. The big issue is very little room to work in up there.
Fran
