BMW M3 Forum (E90 E92)
BPM
      02-02-2009, 10:50 AM   #1
graves4r6
graves4r6's Avatar
56
Drives: Bicycle
Knocking noise coming from the front struts after H&R springs installed
Please help me
It sounds like loose bolts. I rechecked everything and did't find nothing
Thank you.
      02-02-2009, 11:43 AM   #2
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Check if your struts are mounted and torqued correctly.
      02-02-2009, 11:18 PM   #3
graves4r6
graves4r6's Avatar
56
Drives: Bicycle
I found out I didnt torque enough the bolt on the right sway bar link. Thank you.
      02-17-2009, 03:09 PM   #4
Will@WSTO
Drives: 135I
Hay its Will from WheelSTO! I used to be a BWM tech and I installed H&R springs and a H&R sway bar, I test drove it and herd a loud clunk!!! Later to find out the sway bar was to thick and was bottoming out on other suspension components causing a loud clunk! Do you have a upgraded sway bar installed?
      02-17-2009, 03:26 PM   #5
graves4r6
graves4r6's Avatar
56
Drives: Bicycle
Hey Will,
I only installed the springs and it's solved now.
I was so silly for not double checking the right sway bar link.
      02-18-2009, 10:10 AM   #6
NLMiami
///Menace 2 Society
NLMiami's Avatar
Drives: 2009 Jerez E92
I have the H&R springs install with spacers and also seem to hear alot more knocking up front. I had the BMW tech who installed the springs put the car back up on the lift and all the bolts on the sway bar and struts were tight, but still hear some clunking or knocking on uneven roads. I'm taking it in for alignment this week.
Anyone else experience this?? On smooth road and corners, there's no noise or sound. It only seems to make the noises on mildly uneven road patches (even at slow speeds) but it still seems excessive to me.
Thanks for feedback.
m3post
