      11-27-2008, 02:05 PM   #1
spr
93
Drives: F80 M3; e92 ESS650+ M3
Subframe bushing removal tool?
I've noted that a special tool is used to remove the bushings. I have various presses at the shop. I also have a differential bearing removal press that would likely work beautifly. Anyone have pics of a description of the "tool" they are referring to? I didn't see any. Thanks.
      12-01-2008, 05:46 PM   #2
adc
Drives: 2018 F80 M3 ED
+1. I want to know too.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      12-01-2008, 10:46 PM   #3
SoCalTech
Drives: Not a BMW yet...
Not sure about the newer models, but I've seen the subframe bushings being removed on an E34. The tool looked like a two jaw puller, but the arms are fixed, and used to push instead of pull. Then there is a long threaded shaft in the middle that goes through the busing, and threads into a cup on the other side of the bushing. You then pull against the cup, and the two arms put tension against the subframe, and pull the bushing through. This allows you do replace the bushings without completely removing the subframe. Does this help?
      12-02-2008, 10:17 AM   #4
adc
I'm starting to understand, I think... so you do one bushing at a time?
How do you put the new one in? Just tap it with a rubber mallet?
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      12-02-2008, 10:26 PM   #5
SoCalTech
There is a special tool for it too, but we have 60 technicians, and stuff sometimes walks away...
But you can tap in the bushing if you're careful.
      12-03-2008, 03:43 PM   #6
spr
93
Ah so ther're not really that pressed in there then. Nice. They should be easy to remove then as I suspected with enough clearance to put in the driveshaft press.
