11-09-2008, 06:29 PM | #1 |
Rep 30
BBS CH 9x19 ET35 on 135i
Got a good deal on wheels package:
BBS CH wheels 9Jx19 ET35 with 245/30R19 DUNLOP SP SPORT MAXX tyres. The question is - will it just rub sometimes? Or will it be almost impossibe to drive? PS I drive alone almost all the time - no passengers and loadout in the trunk... Any idias? |
11-09-2008, 07:53 PM | #2 |
Slaveaholic
17
Rep 707
it's hard to say. I think that is a really aggressive offset & size. If you don't lower the car, you should be ok with it. But, it will rub if you can live with that.
if you lower the car, it definitely will not work. |
11-09-2008, 09:37 PM | #3 |
Out Driving
29
Rep 685
See I don't know. Lowering the car would increase the negative camber which would make the wheels fit better within the fenders. Either way, I'm betting on slight rubbing.
Emmett
01 E46 M3 |
11-09-2008, 09:49 PM | #4 |
295
Rep 1,201
Fenders will probably need rolling. But, if rolling is done right it should look like nothing has happened.
11-10-2008, 01:01 AM | #6 |
Rep 30
11-10-2008, 07:47 AM | #9 |
2148
Rep 10,176
I have 9" wheels on the front of mine, for racing, and 245's. Those are ET43 though, and I had rubbing, and rolled the front fenders. The rears just barely work as well.
You're attempting to fit a similar fitment, except more outward by 8mm, or almost half an inch more outward. You will not fit those without pretty major rolling, or living with major rear rubbing, plus chewing up those 245's in front. |
11-10-2008, 08:49 AM | #10 |
Rep 30
understood.
thanks to everyone ) PS Tried the tyre/wheel calc combo - the only disadvantage of 9x19ET35 with 245/30R19 against stock wheel+tyres is that it will be rubbing - 17mm rear and 21mm front....
Thank you for your answer.
11-11-2008, 08:56 AM | #11 |
12
Rep 117
BBS CH doesn't exist in 9x19 for BMW...
The only fitment that will do (more or less) for the 1er is: BBS CH 004 front (or front and rear): 8.5x19 ET35 5x120 BBS CH 005 rear: 9.5x19 ET40 5x120 And they rub, you need to widen the arches. I had them on my coupe but I sold them for something with higher offsets (40front and 45 rear). Doesn't rub anymore now.
11-11-2008, 03:56 PM | #12 |
1767
Rep 7,652
has any one tried the 19-8.5 front with +38 offset. i have heard mixed reviews about this. there are quite a few nice wheels out there with this offset that we are interested in selling for the 1er.
11-14-2008, 05:03 PM | #14 |
1767
Rep 7,652
ichiban.... if that works, That thing is going to look awesome. Keep us posted.
08-03-2009, 01:25 PM | #15 | |
Rep 60
08-03-2009, 02:26 PM | #16 |
104
Rep 2,474
you should be able to fit more than that up front.
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks! |
08-03-2009, 02:48 PM | #17 |
94
Rep 1,245
that is basically the same as the current VMR CSL rep set up, except the front will stick out 2 mm more. you will be fine. rears will rub hard if your lowered. BUT a good fender roll will fix that.
08-03-2009, 03:28 PM | #18 |
Rep 60
08-03-2009, 05:32 PM | #19 | |
2169
Rep 2,353
It should look very nice...
BSM ///M2cs, 6spd
08-04-2009, 12:31 PM | #20 |
1767
Rep 7,652
the CH only comes in the following:
CH004 - 19 x 8.5 et35 CH005 - 19 x 9.5 et40 I was actually confused with the BBS RG-R set up: Front: 18 - 8.5 et38 Rear: 18 - 9.0 et45 I think that this will work fine with a roll in the front and 225/245 tire setup.
