      10-21-2008, 09:26 AM   #1
lannypoffo
19
Drives: 2013 Dodge Charger SRT8
my first yellow engine light
happened this morning. i have SSTT.
it happened as i was on the freeway in 6th gear. I floored it to pass someone and the light came on along with the chime.
it will prob be gone when i start it up later, or else i have to buy a reader. I had VW turbos and a vagcom reader for a long time and know these random codes can pop up such as overboost.
but i havent heard of too many lights with SSTT, strange..
      10-21-2008, 09:59 AM   #2
gio
50
Drives:
I had a vagcom for my Audi, unfortunately I don't know of a similar product for BMWs. I don't think one exists.
Waiting on a 2015 M235
      10-21-2008, 10:09 AM   #3
lannypoffo
19
i suppose if it happens regularly ill just have to stay stock. i dont want to be annoyed by a light every few days.
      10-21-2008, 10:28 AM   #4
135iUSN
19 X5 1998 M Roadster
135iUSN's Avatar
64
Drives: 135i Alpine White / Terra
1998 BMW M Roadster  [0.00]
2009 135i  [0.00]
me here. sorry, but SSTT
Super Slick Twin Turbo----
'09 135i Dinan In BMW heaven 09.28.2022 - Stage 2/Alpine White w/Terracotta /High Gloss Black Trim/ZCW/ZPP/ZSP w/313's /CA/PDC/Steptronic/
      10-21-2008, 10:48 AM   #5
lannypoffo
19
Split Second Turbo Tuner.
One of the easier chips to install, similar gains to JuiceBox2. No ECU touching needed which is why I got rid of my JB1.
      10-21-2008, 11:02 AM   #6
135iUSN
135iUSN's Avatar
64
2009 135i  [0.00]
ohh,, ic thx
      10-21-2008, 11:26 AM   #7
Monaco35Dream
Monaco35Dream's Avatar
Drives: 08' 135i, 96' Talon Tsi AWD
2008 135i  [0.00]
do you really think it was the sstt? ive had it for four months now, its only been removed for service, and i havent had any problems or codes other than adaptive headlight failure lol...maybe leave it out for a while and see if it comes up without the sstt installed.
      10-21-2008, 11:28 AM   #8
lannypoffo
19
ya im pretty sure it was sstt.. ive had a lot of turbo cars before this, (Jetta, GTI, WRX), its a common problem. WOT in too high a gear at too low an RPM causes a boost spike which triggers a code.
      10-21-2008, 11:33 AM   #9
Monaco35Dream
2008 135i  [0.00]
hmm well it makes sense the way you explain it...so whats your solution? be careful? lol
      10-21-2008, 11:40 AM   #10
lannypoffo
19
well.. i hope it never happens ever again. or else i might go back stock just for peace of mind. i dont want to deal with lights on a brand new car.
      10-21-2008, 11:40 AM   #11
Red135
La Flama Blanca
Red135's Avatar
27
Drives: 1-series
In some cases it has been to due to the HPFP. With the added boost of the SSTT, it isn't able to keep up with the demand at high throttle.
AMS, Berk Technology, aFe, ER
      10-21-2008, 11:56 AM   #12
warmtoes
31
Drives: EBII 435i xDrive
I took five full cycles of on (driven for some period of time) and then off before my check engine light went off for your reference.
2014 EBII 435i xDrive M-sport
Gone: 2011 TiAg F25 X3 xDrive35i M-sport
Gone: 2008 TiAg w/Coral Red E88 135i Cab M-sport
      10-21-2008, 11:57 AM   #13
lannypoffo
19
isnt that a catch-22 with the dealer? if i take it out, then it wont have a fuel issue and no warranty replacement of HPFP. If I leave it in, to show dealer and reproduce it, warranty voided.. i have no option. it hasnt done it when stock as it doesnt push the fuel enough.
      10-21-2008, 11:58 AM   #14
adc
Drives: 2018 F80 M3 ED
+1.
I would not assumed it's a boost spike. There are stock cars that get the light (and rough running) because of HPFP codes. (Which doesn't mean it will die on you instantly).
Get a simple OBDII reader and post the code here. Also look it up on e90post, there are many codes posted there.
Also try to replicate the problem, with the SSTT in place and then removed.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      10-21-2008, 11:58 AM   #15
lannypoffo
19
thanks, a cycle is full cold to full cold again. so i might be stuck with this for 5 long days.
      10-21-2008, 11:59 AM   #16
lannypoffo
19
Originally Posted by adc View Post
+1.
ya i should buy a code reader either way. i dont want to have to borrow one every time this happens.
but its like this. the dealer isnt going to give me a new fuel pump because my stock one can't keep up with a chipped cars demands.. lol
      10-21-2008, 01:17 PM   #17
lannypoffo
19
stoked.. the light was gone at lunch time. it was one of those temp limp codes which resets as soon as you restart the car. I'll only worry if it comes back regularly.
      10-21-2008, 01:21 PM   #18
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
If it was HPFP related there will be a code stored that the dealer will read, even after your SSTT is removed. Now the dealer may not be able to duplicate the condition without the SSTT installed, but it's worth a visit. They have a battery of tests used to determine low and high fuel pressure issues.
      10-21-2008, 01:24 PM   #19
lannypoffo
19
i'll wait for it to come back once more before i worry. i also read around here that you will not have a code if you dont have a active light. so i am getting conflicting information.
      10-21-2008, 01:27 PM   #20
mikeo
Santa Fe Concorso
mikeo's Avatar
If it's a fuel pressure issue it will store a code.
      10-21-2008, 01:40 PM   #21
lannypoffo
19
hmm ok. then i should buy a basic ODBII reader anyway, just so I can check it.
Do I need a CAN-BUS supported scanner for the 1 series? Anyone know?
      10-21-2008, 02:01 PM   #22
mistermojorizin
mistermojorizin's Avatar
40
Drives: 135i
well, lets start with what you mean by "yellow engine light"? was it a small lite that said "service engine soon" or was it a little picture of an engine half full? Was it accompanied by a limp mode?
if it was a limp it will go away when you restart the car.
"KOPEYKA" /// Titanium Silver / Black Leather / Gray Poplar / Sport Package / Premium Package / 6MT / Feb 08 Production
