10-14-2008, 07:27 AM | #1 |
EVO
7
Rep 193
Will this fit without rub?
I plan getting a set RE30 18*8.5 offset 42 18*9.5 offest:45
and tires will be 235*40 18 245 35 18. will them fit perfectly? even with lower spring? please give some suggestion. |
10-14-2008, 01:11 PM | #2 |
41
Rep 825
I took these off my Z4 and put them on the 135i
Wheels:ASA AR1 Tires: Goodyear Eagle F1 GSD3 Front: 18x8 Offset 45 225/40ZR18 - Tread 7/32 Rear: 18x9 Offset 40 255/35ZR18 – Tread 5/32 I think the fronts are rubbing a little in turns when the wheel sticks out of the wheel well. I am going to put some chalk on the fender where the tire could rub and take a drive to see if the chalk gets rubbed off. The rears are really close to rubbing but have not seen any rubbing in the rear. If you lowered the car I do not think they will fit.
2019 X3 M40i - Black Sapphire Metallic - Mocha Lather - 21" 718M wheels - Every option except Sun Shade
10-20-2008, 04:47 PM | #4 |
223
Rep 1,565
Hmm, i think you'll be okay in the front. Rears will be a tight fit though. It's a toss up for the rears.
We're running 255/35/18 on 18x8.5" +40's in the front. No rubbing but we had to give it a slight roll and dump max camber into the wheels. |
10-21-2008, 02:32 AM | #5 | |
EVO
7
Rep 193
rear one is really hard to find a good offset wheel. a lot people have csl (18*9.5) with similar offset without rubbing. so I guess re30 with 245 tire should be ok. but never know unless i got one. I don't want toss up. thats too expensive. |
