      10-04-2008, 04:23 AM   #1
professor
Drives: Z4 M40i
255/275 correct offset specifictions
I am looking for the correct offset specifications for custom 18 inch wheels with a staggered 255/275 tire setup without fender rolling. I'd appreciate some advice please from those who have done this or are otherwise in the know.
      10-04-2008, 07:23 AM   #2
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
I haven't tried those sizes, mainly because I was having issues with 245/265 on Breyton GTS-Rs. I've learned that our cars do not like tall tire fitments if they are close to the fender lip. Some general observations based on my experience:
1. 8.5" wide fronts will likely be max width without fender work, and offsets of 38-41 are pretty close to optimal for that width. A 255x35 is 25" diameter compared to the OE 215x40 at 24.8", so that's pretty close in diameter. The problem in front is the fender/bumper cover mount bracket and you will surely need to dremel that for extra clearance but may be able to avoid any fender rolling if your car is not lowered. I'm pretty sure I can get 245x35 in front on 8.5" width with et43 even though it would be extremely close to the strut. With 255x35 I expect you will need camber plates to get around -3.0 deg. camber to help avoid the fender lip.
2. In the rear there is a lot more space in the fender well but it takes a lot of offset to use it. For 9" or 9.5" rear wheels the Berk Technology folks have said an offset of et60 would be just about optimal and I think they are probably on the right track. I would add that a 275x35 tire with a diameter of 25.6" may be more problematic than the slightly wider but shorter 285x30 with a 24.8" diameter.
Just my unverified opinions, so good luck and keep us posted.
      10-04-2008, 07:48 AM   #3
professor
Drives: Z4 M40i
thank you for that useful information mikeo. i should have mentioned that i do intend to use camber plates and am not looking to lower my car much if at all. most importantly i am hoping to lower the tire width differential front to back in a non-staggered setup while going up a few sizes so i'd much prefer a 275 rear if the "PNP" type solution berk technology is suggesting works. but your heuristic about avoiding taller fitments is pertinent too. i wish there were some tasteful forgeline, hre or enkreuz solutions to this...
      10-04-2008, 08:18 AM   #4
mikeo
Santa Fe Concorso
mikeo's Avatar
You're welcome, and do keep us posted (and pics ;-)
      10-06-2008, 09:04 AM   #5
WAY
Australia
458
Drives: Fast ones
At a negative camber of 3.0, you are looking at the bare min space between the strut and inner tyre with a OEM set up. Hence, I would be going for an offset of et33-35. For the rears, et60 is about right.
      10-06-2008, 09:27 AM   #6
mikeo
Santa Fe Concorso
mikeo's Avatar
Way, I'm not clear on the meaning of that comment. The strut/spring and wheel/tire move as a unit with camber plates so tire-to-strut clearance should be nearly constant. Have you found that to be different?
      10-07-2008, 12:42 AM   #7
WAY
Australia
458
Drives: Fast ones
Good question Mikeo. I don't know the answer, but unless the stock setup has 5mm between the strut and inner wheel, then I suspect tyre to strurt clearance isn't constant in our cars.
      10-07-2008, 07:38 AM   #8
MINI135i
139
Drives: 2019 M2C and 2013 FR-S
Weird....It seems they would both move together. The only variable should be the tire/rim width/offset when it comes to tire/strut spacing?
Camber is often limited by the spring or top hat hitting the inner fender well, however.
Car is still in transit so I'll have to wait to verify.
