      08-18-2008, 11:23 AM   #1
gan08
14
Drives: Fatty X5 and Pot-bellied 135
Weird noise when turning the steering wheel
Dont know if anyone has experienced the noise...
I turned my steering wheel from a complete stop (pretty much a complete steering wheel turn) and suddenly a weird noise came up.
It sounded loud enough and pretty much like a rock popped to the fender
I didn't worry so I hit the road and drove about 7 miles on hwy and exited a curvy ramp without the noise.
This morning, I backed out from my garage and turned the steering wheel, the noise came back and it got worse.
The noise sounded seriously like driving on a gravel road when turning the wheel.
Does anyone know what might cause the noise?
Thanks.
      08-20-2008, 02:40 AM   #2
Joey_T
That's me...
Joey_T's Avatar
17
Drives: 135i
Is it similar to this? http://www.1addicts.com/forums/showthread.php?t=12963
      08-20-2008, 09:07 AM   #3
JLight
Drives:
Do you have the standard rims/tires? At times if you up size or change tires, they can "rub" against the car when you turn the wheel?
      08-20-2008, 10:30 AM   #4
gan08
14
Originally Posted by Joey View Post
It's different to the thread. I heard the "pop" before maxing out the turn.
There is no leaking and can't recreate the noise.
I'm sorry for the assumptions, i am no mechanic...
Could the weird noise come from
1. bad ball bearing?
2. broken power steering?
3. dislocated control arm?
4. other?
I have standard rims/tires.
No active steering.
Thanks.
      08-25-2008, 12:27 PM   #5
Perfect128
Perfect128
Perfect128's Avatar
10
Drives: '08 SGM 128i
Is it like this?
http://www.1addicts.com/forums/showthread.php?t=7211
Or this?
http://www.1addicts.com/forums/showthread.php?t=13311
      08-25-2008, 04:18 PM   #6
gan08
14
Yes, they were similar to what I heard on the first and second day.
Since then... I couldn't recreate the problem and it seems okay so far. (knock on wood)
I also asked my SA to check if any mechanical problem but nothing was found...
      08-25-2008, 05:54 PM   #7
Perfect128
Perfect128
Perfect128's Avatar
10
Lets all stay on top of this. It appears that many of us have experienced this, but it has been spread to at least 3 threads because we all describe it slightly differently.
I have experienced the noise in my car about 5-8 times. All during the first few miles of driving when it is a hot day and the wheel is turned slightly.
      08-25-2008, 07:25 PM   #8
gan08
14
Summary...
1. first day - POP noise. Turned the wheel from a complete stop. 90F+
2. second day - Rattle noise. Turned the wheel to back out from my garage in the morning about 3mph. 60F+
Since then, it has been okay so far.
Well, I am not sure if this could cause the noise… just a FYI.
What happened prior to the noise…
I exited the ramp. Mid speed turn + break + ran over couple pothole.
As the result, my car bounced a bit during the turn and break.
Parked the car for an hour and came back to drive out from the street parking.
Turned my wheel and I heard POP noise.
