07-31-2008, 06:47 PM | #1 |
43
Rep 829
Daily Short Drives Hurting The Car?
I was told today that daily short drives hurt the car more than long drives. I live less than a mile from work and hardly get out of 3rd gear each way. Because of this, would I need to change my oil more frequently? Warm up the car before driving?
Also, since my drive is usually short I don't turn on the A/C. When I do turn on A/C... I feel a hella noticeable lag. I know it's suppose to... but this is HELLA! It's only the first few gears that I feel the lag. On highway it's super as usual. Had the car for 3 months. Less than 1800 miles.
'08 135i.
07-31-2008, 07:04 PM | #2 |
2148
Rep 10,176
My normal day is driving from my garage to a commuter rail station, 3.5 miles away from my house, and back again, at the end of the day. I guess you're similar to me.
It will cause you to need more frequent oil changes, and it's not great for the car, if that is all you do with it. You also shouldn't need to warm up the car, and if you drive it hard during those short distances, let the car run a little bit before you turn it off. However, I do not feel any of the noticeable lag you described, and I do use A/C. |
07-31-2008, 07:05 PM | #3 |
41
Rep 667
Drives: 135i Coupé
You don't use the third gear within driving a mile? I get on the third gear within 10 seconds from starting unless I'm going 15-20 mph.
I havn't really noticed too much lag with A/C on but thats just me. |
07-31-2008, 07:13 PM | #4 |
43
Rep 829
I hit traffic right when I get onto the street. So it's about 3rd gear max. I have to double check the A/C issue again tonight.
'08 135i.
07-31-2008, 07:16 PM | #5 |
41
Rep 667
Drives: 135i Coupé
That must be tough having all that power and only get to 3rd max I would say take the car out for a drive after you get off. You can avoid short drives and more frequent oil changes.
07-31-2008, 07:32 PM | #6 |
84
Rep 540
Drives: 22 G05, 22 G26
same here I work from home. On our X5 I was told told I need to open it up on the highway every so often.
07-31-2008, 07:54 PM | #7 | |
My gift Registry: M2
119
Rep 1,432
Most of us commute an hour or more..
U r saving tons of gas and time.. Not much damage is done to a car by turning it on and off that quickly.. Engine barely warms up.. you be fine.. cheer up. Quote:
07-31-2008, 09:54 PM | #8 |
7
Rep 237
The manual states to not "warm the car up" and to drive immediately after starting the car. I believe it also mentions not to rev it too hard until the oil temps go up a bit.
I have not noticed any lag whatsoever with the A/C running. How come you don't just walk to work? A mile should take you only about 20 minutes.
08 jet black 135i | sport, 6-mt |
08-01-2008, 01:18 AM | #9 |
24
Rep 507
I live 1.2 miles from work and I use my 1'er as my daily driver. I used the a/c when hot and I don't notice any lag. I do drive very spirited or Possessed LOL! ( did I spell that right? )
on the way there and on the way home I do this twice a day as I come home for lunch!! I would say just keep up on the maintenance!
2008 135i,Dinan Stage 2,Dinan Free flow exhaust.
08-01-2008, 01:39 AM | #10 |
23
Rep 453
We are in the middle of winter here in Australia and I have never turned the A/C off. Never. I will have to switch it off and see if it makes a difference.
08-01-2008, 02:29 AM | #11 | |
417
Rep 6,968
- There's nothing in my pocket other than knives and lint
08-01-2008, 04:43 AM | #12 |
Brigadeer
74
Rep 728
Man, get a bike, a mile to work! I walk nearly that to the train station each day. Help the environment
Eibach Sports springs, Evole Remap, Quafe LSD, AR Downpipes, Forge FMIC, Hart'ge Quads, BMS Intake.
08-01-2008, 04:58 AM | #13 |
NRA Life Member, BMW CCA 30 year member
181
Rep 2,614
Start the car, let the revs settle to just below 1K, drive conservatively until operating temperature, 240 degrees(?) has been achieved, only then do I consider operating the car 'spiritedly'.
A/C lag has not been detected. Daily drive to work is 6.9 miles with a 2-mile stretch@55mph, the relatively short drive does not achieve operating temp even during summer.
Resigned 1ADDICTS Moderator
“To disarm the people is the best and most effective way to enslave them.” – George Mason |
08-01-2008, 01:55 PM | #14 | |
59
Rep 416
penny, WRT the AC and turbo lag, I don't feel any lag with AC ON in my 135i. I read also that the engine map changes with the AC on which should go someway to reduce the perception of any change. Anyway, compared to my 03 STi, where the dip in pick-up was very noticeable, the 135i is light-years better. Mad. |
08-01-2008, 02:40 PM | #15 |
28
Rep 1,938
It's hard on the engine oil to be subject to repeated short milage trips. It gets contaminated with water and fuel, which doesn't burn off unless you take a longer trips where the oil gets hot for an extended period of time. Keep the oil change intervals shorter if you do alot of this type of driving.
08-01-2008, 06:44 PM | #16 |
Rep 56
Right now I'm about a mile from work too. Yet for some reason it takes me about a half hour to get home every night and there are always more miles on my car than that 1. I just can't figure it out
[SIGPIC][/SIGPIC]
2008 BMW 135 Vert Montego Blue Coral Red HGB Trim Cold Weather Premium Sport Comfort Access IPOD and USB Satellite Radio |
08-01-2008, 07:26 PM | #17 |
Molar World
47
Rep 916
i wouldn't worry too much about hurting the car, its under warranty for 4 years.
do yourself a favor on the weekends and stretch the car's legs......remember 3rd gear is good for 100MPH.....i love 3rd gear.
Current: 2016 435i Coupe
Previous: 2014 335i Sedan; 2013 328i Cv, 2011 335i Sedan Gone But Not Forgotten: 2008 135i Convertible (my favorite) |
08-01-2008, 08:05 PM | #18 |
Call
21
Rep 683
Find the time to take your ONE on a spirited trip like on weekends or as often as you can. If you know of a nice twistie section...I know, I know, Texas and those long straights:eyebulge: But surely you know somewhere. She needs to be ripped a little every now and then.
Call
