      06-21-2008, 02:40 AM   #1
WAY
Australia
458
Drives: Fast ones
Brake pads for track?
I tracked my car yesterday and the brake pads didn't hold up that well (cracked around the edges and discoloured). What race pads can I get for this car? My friend has Pagid blue on his Carrera S and it is awesome. But I don't believe I can get it in 135i size. What are those of you who are running a race program doing in terms of pads? Also I have decided to try the BMW performance rotors. I think the fact that they are slotted and drilled will really help in dissapating heat even if they don't give greater braking performance.
      06-21-2008, 05:26 AM   #2
jdgomez
Drives:
What brand of brake pads did you use before? I don't think you can get the same brake pads your friend has for your size.
_____________________
Auto-in-Demand | Autopartswarehouse.com
      06-21-2008, 06:58 AM   #3
m3bs
m3bs's Avatar
62
Drives: 95 S54 M3, X5, GT4, GR Corolla
I know nothing about them, but TMS has these:
http://www.1addicts.com/forums/showthread.php?t=9293&
      06-21-2008, 04:40 PM   #4
r_seng
End Game
r_seng's Avatar
Drives: Devil's Chariot
if you are only an occasional tracker there is not point in getting the "performance" rotors. Cross-drilled and/or slotted rotor are mainly for aesthetics on a DD/weekend track. The truth is that our cars will most likely never see those kinds of temps and conditions to fully use the those kinds of rotors as intended. They also cut the pad life shorter.
To answer your question, I'd go with the Axis Ultimate, great bite, low dust, high operating temps, high fade resistance.
      06-21-2008, 10:02 PM   #5
scottn2retro
scottn2retro's Avatar
496
Drives:
We are going to be trying some pads from TMS on the 135i race car at our next race on July 20th weekend - we'll post a report.
2015 M4 BMW Club Racer
SCTS Racing
https://www.facebook.com/sctsraceteam/
      06-23-2008, 11:09 PM   #6
bradford
28
Drives: 2008 SGM 135i
FYI Axxis Ultimates are street pads. GREAT street pads (my favorite for that task) but street pads nonetheless, and completely unsuitable for track usage.
I like Hawk HT10s or DTC-70s, but I'm not sure if they make a 135i application yet. Ferodo DS3000s are good too. IME, Porterfield R4, Pagid RS14 (Black), and Hawk Blue are not suitable for heavy track use. However, it should be noted that I don't brake until I see God.
Carbotech will make you custom pads if you send them a backing plate.
      06-23-2008, 11:16 PM   #7
bradford
28
$369! LOL
      06-24-2008, 12:34 AM   #8
Kris
123
Drives: m3
Do any of the above 'street' pads reduce the dust?? Ie Axxis,IME,Pagid - im sick of washing my wheels!
      06-24-2008, 12:49 AM   #9
WAY
Australia
458
Drives: Fast ones
Kris, your answer is EBC. But I don't have a clue when they will have one for the 135i.
      06-24-2008, 06:24 AM   #10
bradford
28
Silent, dustless, or effective. Pick two.
Btw, IME means in my experience; its not a brand.
      07-09-2008, 01:40 AM   #11
WAY
Australia
458
Drives: Fast ones
I got some track pads! My local brake specialist (Race Brakes for those in Melbourne) fitted a pair of track pads made for AMG in my car and put in Motul RBF600 in preparation for my 2nd track day on Sat. My factory pads has fine cracks on them and has discoloured completely. He said the front pads are rubbish, but the rears are pretty good pads (made by different companies). They left the backing plate off as the length of these AMG pads are exactly the same as our cars with the backing plate. Woo hoo! I will report back after sat on these and the fluid change.
      07-09-2008, 01:56 AM   #12
professor
Drives: Z4 M40i
lucky the AMG pad lengths match. this would be very interesting to see. keep us posted please.
      07-09-2008, 06:00 AM   #13
AussieRacer
AussieRacer's Avatar
Australia
24
Drives: 2008 135i
Hmmm, I'm confused by what was done. Were the AMG pads a perfect fit with no change required to the pad material and pad backing plate, or did the backing plate off the existing pads have to get "stuck" to the AMG pads?
Or does the 135i front brakes have a secondary backing plate in there as the calipers are a little too wide?
I'm confused as there must be a backing plate in there somewhere between the brake material (which touches the discs) and the caliper pistons. The backing plate distributes the piston load evenly, and stops the situation of the piston rubbing directly onto the rotors.
Current: 135i Auto, Le Mans Blue - w/ Bridgestone RE-11 rears, GP Thunder 7500k angels, & "golf tee" mod plus a few M3 suspension bits and pieces...
      07-09-2008, 06:20 AM   #14
WAY
Australia
458
Drives: Fast ones
No modifiation is required on the AMG pads. He puts it in as is. I believe there is a secondary backing plate there. Not 100% sure as I was in a hurry to leave. Give Howard a call and ask him. I need to go back there next week too so may just ask him as well.
      07-09-2008, 08:34 AM   #15
larryn
This is strange.. do the pad retaining bolts line up too? the stock pads are held in place by two screws for each pad that go through the caliper and into tapped holes on the pads. We need more info! This could be a major revelation...
edit: added pics of the screw locations...
      07-09-2008, 09:30 AM   #16
WAY
Australia
458
Drives: Fast ones
Ok I know what is going on now...it appears that AMG brakes has the same hole dimension as our cars! I took a good look at the new pads and the stock pads. What I said above is wrong. I think what Howard must have said to me is that the new pads are longer, hence more surface area will be swept (which he did say). He also said that he had to not fit the backing plate, which is this thin metal plate that sits between the pads and calipers presumably to prevent/lessen clunking noises. You can see from the blue pads (Turner motorsport?) above that the backing plates are not in place either. The backing plate is molded to the shape of the OE pads, hence it will not fit the AMG pads. So what does this mean? Great news everyone, we have many options as I am sure the likes of Pagids, Ferado etc make pads for AMG! I will find out for you guys what model AMG it is...
      07-09-2008, 09:37 AM   #17
larryn
That was going to be my next question!
WOOOOT!!!
      07-09-2008, 09:39 AM   #18
WAY
Australia
458
Drives: Fast ones
And the extra plus is that the AMG pads are longer hence will give us better braking power presumably. I am now wondering if that is all Turner motorsport did - took an AMG pad they make and sell them as "exclusive" 135i pads?
      07-09-2008, 10:15 AM   #19
BMWeber
36
Drives: 08 135i
Turner is actually getting there pads custom maid at the moment pretty much by hand. especially seeing as they are using the cool willie compound witch is there own.
by the way any idea what AMG that is yet :biggrin:
      07-09-2008, 10:23 AM   #20
BMWeber
36
Drives: 08 135i
if you could take some pictures that would be awesome also :thumbup:
      07-09-2008, 06:55 PM   #21
WAY
Australia
458
Drives: Fast ones
Bad news. They don't actually know what AMG model it is! They were commisioned to make a few of them previously and these are the leftovers. He also said that it isn't perfect fit and he had to modify it a bit but the holes fit exactly. Back to the drawing board I think.
      07-10-2008, 10:47 PM   #22
scottn2retro
496
Drives:
We received some brake pads from Turner - but we found out there is a very good reason for why they are expensive. They are essentially custom brake pads.
What they made for us are Hawk HT-10. They take a very large, expensive Hawk pad and custom machine it down to the size for a 135i. Considering that the pad makers have not put out any pads in mass production yet, it's a great alternative. I guess they can make you just about any kind of pad you want (PFCs, etc.) using that method.
SCTS Racing
