04-11-2008, 08:34 PM | #1 |
23
Rep 374
DYNO Results: DINAN/BMS Intake
Hello Everyone!
So today I told my CEO that I had a "doctors appointment from 12 till 2". Secretly I sped on over to MD automotive in Westminster, CA to run a Dyno on my 135i! (Dont tell on me!) What I have done to the car so far: DINAN Stage 1 Flash BMS Intake "Gold Tee" exhaust (I actually used a ball-bearing) From other posts and my own research the below numbers are almost pretty darn close to correct for a stock baseline 135i: 263 wheel Horse Power at 5500 RPMs 274 foot pounds of torque at 3250 RPMs I will discuss no further about my vehicle and simply show you a video as well as the dyno results Video of Dyno (wait till it hits 30 seconds...oh and sorry I forgot to insert my shout-out 1addicts.com) Dyno Results Picture fixed Max HP 323 Max Torque 354 Max Boots 14 psi A note regarding the BMS intake: I really do not care if it gives me more horsepower or not. The sound in of itself is reason enough for me to keep it. I LOVE hearing the turbos spool up. I will be keeping an after-market intake as long as it does not show a loss in power over stock |
04-11-2008, 08:40 PM | #2 |
77
Rep 1,376
Drives: 1988 M3, 1990 M3, 1998 M3/4
Garage List 1998 BMW M3/4 [10.00]
2011 BMW M3 Sedan [9.28] 1988 BMW M3 [9.40] 1990 BMW M3 [10.00] 2008 BMW 135i - sold [0.00] 2003 BMW M3 - sold [0.00] |
sweet, that is tempting :wink:
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black 1998 BMW M3 - Alpine White/Mulberry 2011 BMW 328i racecar - LeMans Blue/Black |
04-11-2008, 08:58 PM | #4 |
Michelin Man
388
Rep 740
wow that is really disappointing on a dynojet, stock 135i has dyno'd at 290hp on a dynojet, the 263/274 number is on a mustang which reads much lower than a dynojet.
I would try it again with the stock intake and see if there is a difference, you should be making 350+ on a dynojet though. |
04-11-2008, 08:59 PM | #6 | |
23
Rep 374
BMS states a min gain of 8 to 15 hp. BMS reps...can you explain any of this? |
04-11-2008, 09:27 PM | #9 |
79
Rep 1,597
I saw that too, I thought I was going crazy for a second
04-11-2008, 10:16 PM | #11 |
167
Rep 4,311
Drives: Supercharged E90 M3
This is wheel horsepower right?
04-11-2008, 10:32 PM | #14 | |
13
Rep 249
EDIT: or does it have to do with the fact that it's been done on a dynojet? |
04-11-2008, 10:50 PM | #15 |
Michelin Man
388
Rep 740
it's the dynojet, it should be reading more like 350hp/380tq to equal the dinan claims of 384/421. the only way to know for sure would be to do a baseline dyno stock then dyno with the flash, same car, same dyno.
04-11-2008, 10:51 PM | #16 |
Rep 53
There is a possibilty that the intake is making you lose power. Like someone said above, you should dyno again with a stock intake...it is probably why your A/F ratio is off.
04-11-2008, 11:48 PM | #19 |
Rep 53
Numbers look good, air/fuel ratios look good. The Dinan tune does 315-320rw on 91 octane so you're right on par. And some dynos read higher or lower than others. A stock 135 should do around 270rw on a dynojet.
04-11-2008, 11:51 PM | #20 | |
Rep 53
Here are some examples: 315, 316, and 320 rwhp: http://www.e90post.com/forums/showthread.php?t=111530 315rwhp: http://www.e90post.com/forums/showthread.php?t=105689 |
04-11-2008, 11:52 PM | #21 |
Rep 53
Impossible! We've done a lot of dyno testing and there are gains every time. And the air/fuel ratios are closed loop so no intake mod can change them. Only an ECU flash or piggyback can alter the air/fuel ratios.
