BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > Private Sellers - For Sale / Trade / Wanted > Cars for sale/wanted/trade
EXXEL Distributions
      04-25-2024, 06:12 AM   #1
kk2
9
Drives: ....
FS: CT - AW 2011 E92 M3 6MT ZCP Stripper w/52k (CF Roof, Single Hump, Speed Cloth)
USD 59,500.00
Or Best Offer
First off, this car isn’t going to be for everyone. If it’s not for you, then that’s ok. However, if you get it, then you get it.
DM me if you’re interested and I will provide the VIN and window sticker.
Clean carfax with title in hand (no lien)
I bought the car stock in December of 2020 with 49,xxx miles. It was a great base, that I’ve taken the opportunity to improve on through some tasteful mods and maintenance. The car is probably a 9/10 for the miles. It has a paint chip here and there. It’s not anything that would annoy you, but I feel obligated to disclose. There has been ppf on the headlights since I bought the car. I added ppf after polish and before coating on the roof.
The stock ZCP wheels (cracked and bent) and brakes are not included. Almost everything else, including the complete stock x pipe and seats, is. Even stock motor mounts and rod bearings, in case you wanted to see what they looked like when I had them pulled out.
I CAN MAKE THIS CAR 50 STATE LEGAL BEFORE TRANSPORT IF THAT MATTERS TO YOU.
Below is the list of maintenance and modifications done under my ownership.
5/2021 @ 49,400 (AutoCouture)
  Inspection 3 (valve/timing cover gaskets, spark plugs, cabin air filter, coolant/PS/trans/diff/brake flush)
  BE rod bearing replacement
  Turner Motorsport power pulley kit
  AFE cf intake kit
  Bimmerworld group N motor mounts
  Ultimate clutch pedal
6/2021
  Recaro Pole Position ABE in cloth with Brey-Krause side mounts on OEM sliders
  MJunkee GTS style armrest
7/2021 @ 49,800 (AutoCouture)
  KW Clubsport 2 way coilovers
  SPL rear toe links with eccentric lockout kit
  SPL front caster rod monoball
  Fall-Line billet aluminum trailing arm
  Fall-Line rear sway bar end links
  Fall-Line rear camber shim conversion
  3DM rear trailing arm ball joint conversion
  New OEM suspension arms that were not replaced by Fall-Line
  Turner Motorsport solid subframe bushings
  Turner Motorsport rear shock mounts
  Hotchkiss sway bars
  Stoptech stainless steel inner and outer rear brake lines
  Coding for passenger occupancy sensor, GTS MDM, and TPMS delete
8/2021
  Volk Racing TE37 SL
    18x9.5/10.5
    265/285 Michelin PS4s
5/2022
  OEM chrome kidneys and side vents (have stock black chrome)
6/2022
  Active Autowerke primary cat delete test pipes on a different x-pipe than stock
  OEM replacement transmission mounts
4/2023 @ 51,800 (AutoCouture)
  F8x M3 front suspension uprights
  F8x M3 front and rear brakes/rotors
  F8x M3 front and rear hubs and wheel bearings
  Stainless steel front brake lines
  MSI press in wheel studs
  Core4 floating lug nuts
  Turner Motorsport undertray
  GTS style cf front lip
  Remove windshield to replace gaskets and mouldings
4/2024
  Rogue Engineering license plate bracket (black ti hardware)
  Rogue Engineering exhaust support bracket (gold ti hardware)
Appreciate 2
      04-25-2024, 11:35 AM   #2
rallenross
rallenross's Avatar
Drives: F80
Perfect.
      04-26-2024, 02:51 PM   #3
omak81
omak81's Avatar
148
Drives: 2020 M2CS Black/Black Manual
More photos of interior and engine bay? Where is this located?
1985 Euro E24 M6 5Speed - Graphite Metallic/Black Buffalo Leather
1998 E36 M3 5Speed - Titanium Silver/Black Vaders
2011 550i X Drive M Sport - Carbon Black/Cinnamon
2020 M2CS 6Speed-Black Sapphire Metallic - Black Style 763M
      04-26-2024, 10:19 PM   #4
kk2
9
Drives: ....
Located in CT. I’ll upload some more pics tomorrow.
      04-27-2024, 07:03 AM   #5
kk2
9
Drives: ....
Not 100% sure what you were looking for but I updated the OP. Hope this helps!
      05-08-2024, 06:21 PM   #6
kk2
9
Drives: ....
      05-08-2024, 11:49 PM   #7
HELROTM3
916
Drives: 1995 e36 M3
Stunning! Keep it!
m3post
