      04-04-2008, 02:29 PM   #1
AndyM
AndyM's Avatar
134
Drives:
Let's remove the brake and shift boots
I am moving to a new host for my site and do not want to go through all my posts to keep images. As a result, I have converted this post into a PDF you can download.
      04-04-2008, 03:01 PM   #2
AndyM
AndyM's Avatar
134
Drives:
Could someone with a 128 please let me know if the shift knob is connected to the shift boot in the same way as I posted? Thanks.
      07-11-2008, 12:40 AM   #3
Bullitt
Bullitt's Avatar
91
Drives: 135i
2008 135i  [0.00]
Surprised there is no mention of this on this forum or other bimmer forums: the two teets that are next to each other on the bottom of the ///M shift knob must be broken off in order to separate the knob from its boot. Otherwise, the knob will not remove. It has to do with the bottom of the teets, which is much larger than the holes it must be disconnected through. This may apply only to later productions as I have a May build and it appears BMW has modified these two teets since this DIY.
      05-18-2009, 04:14 PM   #4
Alow
Alow's Avatar
38
Drives: E82 128i, F36 430i GC
Andy,
Would this DIY work to install the new BMW performance e-brake? I think a new lever is included, not just the boot. How does the lever come off? I'll probably find out once I do this, but I wanted to see if you knew before I attempt it.
      05-18-2009, 06:27 PM   #5
AndyM
AndyM's Avatar
134
Drives:
Originally Posted by Alow View Post
Andy,
Sorry, I'm not sure. If the ebrake is like the E46 one, you remove the boot and then can remove the entire handle assembly. Then adjust the handbrake cables.
      05-25-2009, 02:34 PM   #6
SlickShift
SlickShift's Avatar
323
Drives: '11 BMW E90 M3 ZCP, '21 X5 ZMP
Do you have any pictures of one of your alcantara shift boots and/or e-brake boots on a 1er?
-Nick
2018 BMW 440i - M Sport, Exec
Glacier Silver Metallic/Coral Red Dakota
Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i
      05-25-2009, 02:57 PM   #7
AndyM
AndyM's Avatar
134
Drives:
Here you go]
      05-25-2009, 04:29 PM   #8
SlickShift
SlickShift's Avatar
323
Thanks! I'm still on the fence on whether or not the perforated leather looks good with alcantara. Hmmm...
-Nick
      04-05-2012, 10:59 AM   #9
golf_234
325
Drives: E46, E90, F30
Thank you! worked perfect.
      07-17-2012, 01:47 AM   #10
woosh
woosh's Avatar
Australia
212
Drives: rs
I felt the need to bump this up. Took me by surprise that the other two teets weren't exposed to be unclipped.
Easiest way to do this is, after having unclipped the first exposed teet, stick a thin screw driver from underneath (between the knob and boot/gaitor) and gently twist. This pulls the two teets up out of the glue/resin. There is no clip inside, so it comes straight out. Just make sure not to leave marks on the silver part of the gear knob!!
