      03-23-2008, 01:05 PM   #1
eunosracr
159
Drives: a car
Heads up on blow off valves on the 135i
AFTER TEST FITTING WE FOUND OUT THE UR BOV FITS!! I HAVE IT INSTALLED AND IT WORKS GREAT!!!!
I bought the UR 335i blow off valve kit to fit on to my 135i a few months ago thinking it would fit because it was the same engine. I tried to install it yesterday and the intake pipe that goes connected to the throttle body is totally different in the 135i. Thus, the 335i blow off valve kits will not work on the 135i. Vendors please get to work on a kit for the 135i. Thanks in advance!
      03-23-2008, 01:55 PM   #2
Mikebuzzsaw
7
Drives: Alpinewhite BMW e46 M3
Thats good. Sell the BOV and never buy one again. :thumbup:
      03-23-2008, 02:11 PM   #3
eunosracr
159
Drives: a car
I have it up for sale. I need a BOV or Forged DV because I have read the stock plastic ones are good for only up to 12lbs of boost. Let's just say Im running a bit more than that bwahahaha.
      03-23-2008, 02:17 PM   #4
dim135
Drives: bmw 135
forge DVs
      03-23-2008, 02:20 PM   #5
eunosracr
159
Drives: a car
Originally Posted by dim135 View Post
forge DVs
Definitely looking into these!
      03-23-2008, 05:08 PM   #6
coco_m3
coco_m3's Avatar
Drives: Supercharged E90 M3
2008 BMW M3  [0.00]
2010 BMW E90 335i  [0.00]
buy AA's! and post pics so i know if i want it...
      03-23-2008, 05:12 PM   #7
turbomg
Acquiring the taste.
Drives:
Says who? I've spent a lot of time over on e90post, and I don't think this is a commonly held opinion. Many people are replacing their diverter valves, but that has more to do with improved function and response over the stock units, not any fear of blowing them out with too much boost pressure.
      03-23-2008, 05:29 PM   #8
eunosracr
159
Drives: a car
I am going to talk to them tomorrow while they are fitting the intercooler. Their current BOV will not work either. Its missing a pretty big hole the 135i intake has which some hose goes connected to.
      03-23-2008, 05:30 PM   #9
blacknbean
14
Drives: e92 335i 6MT
agreed
      03-23-2008, 05:31 PM   #10
eunosracr
159
Drives: a car
I have read that over on E90, as well as the stock units possibly failing at higher boost levels. Im going to try and find the link.
      03-23-2008, 07:09 PM   #11
mtla4
42
Drives: Turbo Festiva
Sell the Bov as someone said get a Dv. As an Audi Guy I can understand that you want some PSSHHHITTTT sound but you'll probably end up running richer and throwing CEL. Stay with Dv or if you want some sound a CAI will help. Worst case scenario an hybrid BOV(on 1.8t 80% recirculated-20% air) or twin piston like the forge 004.The turkey sound is annoying some how. Dv for me this time
      03-23-2008, 07:24 PM   #12
eunosracr
159
Drives: a car
The n54 runs a MAF sensor not a MAP sensor so venting to atmosphere does not cause it to run richer or trigger cel lights. I will probably end up running Forged dV's. We will see.
      03-23-2008, 09:48 PM   #13
TunedM2C
TunedM2C's Avatar
829
Drives: 2016 LBB M2
forge DVs
+1
      03-23-2008, 09:50 PM   #14
TunedM2C
TunedM2C's Avatar
829
Drives: 2016 LBB M2
Thanks for being our guinea pig!
      03-23-2008, 10:31 PM   #15
Jockey
Jockey's Avatar
3451
Drives: 992 C4S
except that the air is metered well before the BOV so you're venting off excess air the ECU thinks is there but isn't...
unless you're running alot more boost over stock, BOVs are just about bling
      03-23-2008, 10:31 PM   #16
eunosracr
159
Drives: a car
Ha my pleasure.
      03-23-2008, 10:33 PM   #17
eunosracr
159
Drives: a car
Would you consider twice as much boost as stock alot?
      03-23-2008, 10:38 PM   #18
Jockey
Jockey's Avatar
3451
Drives: 992 C4S
depends, 3 to 6 psi, no ; 15 to 30, yes
nonetheless, if the stock one can hold that pressure, then it's a waste
but if it can't, then it's worthwhile
      03-23-2008, 10:44 PM   #19
eunosracr
159
Drives: a car
I'm running 14.5 right now so I guess im borderline....
      03-23-2008, 10:44 PM   #20
sndprssr
Tech. Certified
Drives: '08 135i
You have that backwards, it runs a MAP snesor not a MAF sensor and you wouldn't have to sell the BOV, just route the vent back into the intake instead of buying a diverter valve seeing as how they are basically the same thing.
      03-23-2008, 10:45 PM   #21
eunosracr
159
Drives: a car
I stand corrected thanks. Im selling because the pipe for the 335i intake is totally different than the one for the 135i. So the current BOV kits wont work.
      03-23-2008, 10:50 PM   #22
sndprssr
Tech. Certified
Drives: '08 135i
The air is also metered AFTER the BOV, in the manifold, hence the Manifold Absolute Pressure (MAP) sensor so the ECU doesn't think the vented air is there.
