02-07-2024, 07:56 PM | #1 |
30
Rep 107
Cons first: Rebuilt title due to an accident in 2017 not in my ownership. Car was hit on the driver side and has been fully repaired. ECU was replaced with a used E9x ECU due to a crazy occurrence that I can only think was the positive battery terminal recall shorting out during my ownership. Car has 112,000 miles. Carbon roof is a 9/10 with normal marks in the clear coat. Also a rock chip on the windshield. I’ve owned this car for over 5 years and have put a lot of money and love into it. It is an incredible car that will run for a long time with proper care. JMP Autowerkz and MRF Engineering have taken good care of the car with maintanence. Maintanence in my ownership w/ all receipts - Rod bearings ofcourse have been done with photos - Throttle actuators replaced - New alternator - Poly subframe and differential bushings - Spark plugs multiple times - New ignition coils - Brand new rotors & pads all around - Oil and filter done every 3-6k - Recent differential & transmission fluid/filter change - Brand new differential casing - Brake booster new hoses and sensor - Brand new OEM valve covers and gaskets - New Timing gaskets - Europower Motorsport aluminum vanos covers - New windshield weather stripping Mods: - 18 inch BBS RIA bought new (PS4S tires) - Wheels coated with CarPro DLUX - KW Clubsport 2-way adjustable - Billet Aluminum upgraded power steering reservoir - M perf alcantara flat bottom steering wheel - light up oem f10 shift knob wrapped in alcantara by forums member - Coby wheel alcantara shift boot - Short shift kit - Autopower half cage red - Clean rear seats are taken out in a box - Black aluminum pedal haus pedal set from IND - Hardwired passport 9500ci that works but the screen that is in the rear view mirror stopped working - MLT Engineering Aluminum undertray - Carbon Vorsteiner vented hood - Carbon GTS wing from forums member - Carbon front spoiler - Stock x-pipe - IPE F1 Valved Mufflers with receipt/box - Car is ceramic coated with adams advanced graphene Extra parts that I could include w/sale: - Macht Schnell resonated x-pipe - Titanium Vorsteiner muffler - 19 inch Vorsteiner VSE-001 w/tires - Original ECU - KW v3’s - probably some more things |
