01-16-2024, 12:21 PM | #1 |
62
Rep 35
Front Bumper Bolts
Hi all,
About to tackle a front lip install and have it mocked up. I removed the four bolts that go into the bumper in the center. They are too short when the CF lip is installed. I verified and the bolt is not long enough to go through the CF lip and back into the bumper. 1) Does Anyone know the OEM bolt pitch/thread/size? From some research, I was able to find that it may be a Hex Head Screw with Washer ST4, 8x16mm. 2) Any other suggestions that I can use that will fit the OEM holes/bracket? Thanks! |
01-17-2024, 05:47 PM | #2 |
1393
Rep 1,357
Need details. Different lips require different mounting options and hardware.
What type of lip? M performance or CS style? If CS style, are you using oem mounting brackets?
MGM Ext, SO int, Euro IKON, CS front lip, Carbon 1.5 diffuser, GTS/CS coding, M perf rear spoiler, & everything else STOCK.
(Previous E39 and NA1 NSX owner) Those were the days! |
01-19-2024, 05:40 AM | #3 | |
62
Rep 35
Thanks |
01-20-2024, 07:58 AM | #5 | |
62
Rep 35
I would post a picture, but all of the parts are at the shop getting PPF before the installation and I was just shopping around for the longer bolts in the meantime. |
01-20-2024, 03:20 PM | #6 | |
546
Rep 1,061
01-20-2024, 04:23 PM | #7 |
1393
Rep 1,357
I think you need a M6X20 bolt with standard non machined thread but cannot confirm. Left my calipers at work Friday.
01-21-2024, 10:11 AM | #8 | ||
62
Rep 35
02-07-2024, 11:40 AM | #10 | |
455
Rep 2,066
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
https://www.realoem.com/bmw/enUS/sho...diagId=51_5553 BMW uses 3M double sided adhesive tape I believe. Here’s a pic of the self tapping screws they have listed. “TS5 x 20mm” torx head 20mm self tapping Personally, I would modify this install via some over engineering by purchasing either titanium or stainless steel hardware to ensure no rusting occurs as it can eat at the CF over time leading to discoloration and deterioration as well 🤷🏼‍♂️
2017 F80 ZCP BSM - Klein Innovation. ActiveAutowerkes. AR Design. BootMod3 Paul Johnson. EvRw. Project Gamma. RW Carbon. UCP. UUC. Hawk. Dinan. NGK. Macht Schnell. TMS. VR. aFe.
RIP - E82 135i - 7/7/2021 |
YMBDrew62.00 |
02-11-2024, 08:57 AM | #11 |
62
Rep 35
Not sure why the forum didnt notify me of this response.
Thank you for taking the time to post that response. Very helpful. I ended up going with new SS hardware and adapted the undertray to accept the new screw without drilling. |
NORAGRETS455.00 |
02-14-2024, 12:08 PM | #12 |
455
Rep 2,066
No worries hope it went well!
YMBDrew62.00 |
