02-09-2008, 11:33 PM | #1 |
Rep 13
Business Navigation System - Changing Maps
Hi all!
Here in Brazil the BMW do not sells the DVD maps (but sells the iDrive with navigation system...). Because this, every time I start the car, the navigation disc is required. I cannot turn it off. My model comes with the Business system (I identified it using the documents on the Internet). Looking in the internet I found several DVD's for the BMW Navigation Systems : BMW High, Professional and Business. I downloaded every one that I found on the internet. The only one that works is a Business Navigation DVD. When inserted in the car it works fine! Well... It has the European map. But the screen do not more ask me for a Navigation DVD and the general options of the GPS system is working (vehicle position, for example). Now I want to go a step forward : change the maps. All the tutorials in the internet talks about the Professional, the High or a Business system - but in all tutorials that I find, the DVD structure is not the same. This is the structure : DATABASE.BD kNT064EU16x01-F.DB HBINFO_MAP.TXT INFO_MAP.TXT KN064eu16x02-G.DB2_GDB KN064eu16x02-G.DB2_INF KN064eu16x02-G.DB2_LIT KN064eu16x02-G.DB2_SDS KN064eu16x02-G.DB2_SP5 KN064eu16x02-G.DB2_XAC The first one (DATABASE.BD) is a pdf file - all you need to do is rename it (I attached it). Anyone knows this structure ? How change (it appears to be compiled to me) ? Thanks for any help.:thumbup: |
02-10-2008, 09:16 AM | #2 |
2148
Rep 10,176
Why would BMW sell nav (or you buy nav) if there's no maps for it?
Have you tried to see if Navteq will make a version for you? They did announce that they were making Brazil maps a while ago. Over on e90post, I remember somebody who was able to insert waypoints, and figured out the structure of the DVD. You might want to check there. |
