ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics
      12-28-2023, 11:30 AM   #1
Isaac.
11
Drives: E36 M3, E90 M3
Can't clear D016B4 code on '18 M3
Wondering if anyone has come across this code before.
D016B4: Message error (system status electric vehicle drive, ID: SYS_ST_EVEH_DRV) - timeout
This code was discovered on a routine scan. The car is totally stock and has zero driving issues. I don’t notice any strange driving behaviors. There are no messages on iDrive and no warning lights. It points to the ICM but search of these forums suggests a broad range of potential causes—anything from wheel speed sensors to power steering module to a damper sensor. However, common to most of these is the “Chassis stabilization” message on iDrive and I have never had this.
The error appears with both BimmerLink and a higher end Foxwell scanner set up for BMWs. Neither one seems to be able to clear it. Thanks in advance.
      03-29-2024, 08:57 PM   #2
Driven By CM
Driven By CM's Avatar
Drives: 2020 BMW M4 CS
2020 BMW M4 CS  [10.00]
Did you ever figure this one out?
I just discovered the code on my car and am trying to figure out what the problem is. Bone stock 2020 M4 CS here (I have done some very minor coding, however).
f80post
