10-30-2023, 08:20 PM | #1 |
Rep 5
F80 M3 limp mode not revving over 3k rpm
A little back story, I bought this car from fb for a steal bc he was unable to get it fixed so I thought i'd be up to the task. But tbh I don't know where to begin. The owner told me that the car previously had an m4 dme. So he went ahead and ordered a dme already programmed for the car from Bmw. The car starts but there is a low oil pressure code that's intermittent and it won't allow you to rev or drive the car above 3k rpm. The oil level reading stops at 2% so I have yet been able to check the oil. I tried unplugging the mass air flows but still the same thing. I believe the car is in limp mode but there is no drivetrain malfunction. Any information or thoughts on what can be the issue will be appreciated.
11-03-2023, 10:07 PM | #2 | |
Racecar Driver
1323
Rep 2,003
Drives: BMW M4
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
Ogkwaik0.00 |
11-05-2023, 01:09 AM | #3 |
Rep 5
The only code that's coming up is a Zero gear sensor adaptation not learned. Also sometimes the only pressure warning comes on code 1fb801. The oil level stops at 4% so I have yet been able to check the level.
11-05-2023, 07:19 PM | #5 |
Rep 5
Im thinking of doing the crank hub and in the process changing whatever needs to be changed. But I do think this issue is an ecu issue. Im thinking of sending it of to get it looked at to make sure the coding is correct.
11-05-2023, 07:23 PM | #6 |
Rep 5
But on a second note I just purchased a 2011 535i with the n55. Sounds like it has no compression, it cranks but doesn't start. Checked compression every cylinder had 0 compression. Looked at the timing and it looked to be off pretty badly. Do you think the valves were affected. I plan on adjusting the cams and then doing a leak down test.
