08-13-2007, 09:45 AM | #1 |
2431
Rep 11,667
Start Button Location....
Anyone else wonder why they located the Start/Stop so high on the dash????
Looks like crap on top like that - it would have looked better below the fob slot & just as functional
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
08-13-2007, 09:48 AM | #2 |
Santa Fe Concorso
103
Rep 2,984
Yeah, and does anyone beside me have a problem with the bright aluminum trim in the black interior? I will most likely select the black trim.
08-13-2007, 09:56 AM | #3 |
565
Rep 3,742
I have never been a big fan of the start/stop button. I prefer a regular key. Nevertheless, I agree that the button is too high in the 1er coupe. The location of the button in the 3-Series is more acceptable.
08-13-2007, 09:59 AM | #4 |
12
Rep 445
Funny, I was noticing the general lack of instrumentation, the absence of touchscreen navigation, and the incorrectly positioned power window switches.
In regard to the upper photo with the higher placement, I prefer the higher placement of the start/stop switch. Although none of us has substantial long term direct experience with both, the higher switch seems easier to see/reach, whereas the lower switch appears concealed behind the thick arm of the steering wheel as seen from the drivers position. That's probably exactly why it was moved, as a result of negative customer feedback on the 1st generation 1 series. Controls don't get moved for no reason. |
08-13-2007, 10:11 AM | #5 |
22
Rep 908
Without actually getting inside, I'd be a little nervous that something could accidentally hit the start/stop button with it lower like that :iono: But then again, this'll be my first button-start car so I don't know how sensitive the button is It definitely LOOKS better lowered like that
Vorsprung durch Gas Geben!! 172 of 740 |
08-13-2007, 10:15 AM | #6 | |
20
Rep 722
08-13-2007, 11:28 AM | #7 | ||
Rep 80
08-13-2007, 12:33 PM | #8 |
Rep 30
Will you still have to put a key in a slot? I rented an Altima for business the other day and while it did have a slot for the key, you could keep it in your pocket and just hit the button. Stupid gimmic trend!!!!!! Useless. Reminds me of push button transmissions and tail fins.
08-13-2007, 12:54 PM | #10 |
Rep 6
also, what is the cars center stack going to look like with a normal radio (ie if you dont order nav/idrive)? or would they even put it down there, I probably should have looked for pics of other 1-series dashes, but hey, laziness is a bitch
nevermind, just found it over in the photos forum, looks good, guessing the nav screen becomes storage |
08-13-2007, 01:01 PM | #11 | |
2431
Rep 11,667
It still gets the NAV compartment on the top of the dash.
08-13-2007, 03:28 PM | #13 | |
12
Rep 445
And as far as pushbutton transmissions go, its not the Edsel days anymore. The new Aston Martins have push button transmission controls right under the A/C vents in the center console and its a very smart idea that gives useful room in the center console right where a big stupid waste of space shift lever normally resides. You must be a luddite. |
08-13-2007, 03:51 PM | #15 |
Large Member
164
Rep 937
I've been babysitting a co-worker's Prius this past week. The push-buttong start + inserting the key is a complete PITA. If you just need the key in your pocket (Comfort Access) then push botton would be nice. But needing to insert the fob and then push the button is silly.
08-13-2007, 05:46 PM | #17 | |
2431
Rep 11,667
That's the ONLY reason I'll consider comfort access, though it burns my a$$ to do it.
08-14-2007, 11:17 AM | #18 |
Zoom Zoom
38
Rep 1,069
Having used the BMW keys thousands of times, I really dont have any complaint with the system. At first I thought Comfort Access would be nice (I have it on my Mazda) but having to pay 500+ dollars (keep in mind the cost of the option varies on every BMW model) for silly convenience is a waste. With the way that some keys make you push and twist, the simplicity of the BMW system is great.
In the garage: 2022 G80 M3 Manual - Portimao Blue
08-14-2007, 12:50 PM | #19 | |
2431
Rep 11,667
I have a hard time spending $500 on something like CA as well. :iono: maybe I can get it tossed in as a deal closer :smile:
08-14-2007, 02:10 PM | #20 |
936
Rep 1,180
08-14-2007, 04:11 PM | #21 |
Zoom Zoom
38
Rep 1,069
I like your thinking...
08-14-2007, 04:59 PM | #22 |
2431
Rep 11,667
It works sometimes...
On my M Roady I got the 6 CD changer as a toss in to close the deal.
