      08-01-2007, 05:04 PM   #1
Harold
Drives: Z3 Coupe
Exclamation 2007 Engine Tech: How the N54 turbo engine works (must read!!!)
PDF Files:
2007 Engine Introduction (right-click-save-as)
2007 Engine Management (right-click-save-as)
2007 Engine Mechanical (right-click-save-as)
2007 Engine Technology (right-click-save-as)
ENGINE INTRODUCTION
ENGINE MANAGEMENT
      08-02-2007, 08:50 AM   #2
Madjack
Drives:
That should clear up some questions about the blow-off valves.
      08-15-2007, 05:08 PM   #3
240M3SRT
***** badass
240M3SRT's Avatar
Drives:
"a clearly noticeable, disruptive pumping noise can be heard"...haha, yea its called blow-off.
Im not sure that section really determines whether or not they can be externally vented. One issue i can see would be the idle suffering like it does on MAF cars. And its probably monitored by the ecu too well to "trick" without adverse affects.
The air is read by an HFM, but im unfamilair with those.
      08-16-2007, 02:34 PM   #4
Sperm
Drives: 2002 Impreza WRX
Very informative thread. Thanks.
      10-31-2007, 05:59 PM   #5
DonArm
Drives:
Good info to start with ; )
      11-03-2007, 01:35 PM   #6
Ryephile
Not a Newbie
Drives:
Of interesting note is how the wastegate system is different than popular aftermarket turbo wastegates. The BMW setup is a "pull closed" wastegate, where it defaults to being open. This is opposite to aftermarket setups where the wastegate is held closed until the pressure transducer is presented with pressure to open it. The BMW system provides safe failure mode operation and improved control resolution over traditional setups.
[SIGPIC][/SIGPIC]
      11-19-2007, 03:51 AM   #7
Drex
Drives:
"Do not make any alterations to the turbocharger. Never attempt to alter the boost-pressure control linkage. The turbocharger has been optimally configured at the factory. If the turbocharger operates at higher boost pressures that permitted by he engine manufacturer, the engine may run hot and pistons, cylinder heads or engine bearings may fail, or the safety function of the engine electronics may respond an activate the engine's limp-home program."
This last section particularly interested me. Coming from a subie where pretty much everything is mechanical...to this where everything is controlled by computers, i get a little worried about going crazy with mods.
my intentions were to go with IC/chip/exhaust. But i see some companies increase boost up to 14psi while others only bump it up a little. When i got a boost controller on my wrx, I only bumped it up a lb and i felt a noticeable difference, and that was only a BC and not a chip.
So i worry that the chips that bump it up too much may run inline with that statement that said the engine could run too hot. While this may not pose any problems in the first year...what about when the 4yr/50k (some people can put 50k on in a year btw) mile warranty runs up and you have blown engine... I wouldn't even want to think about how much that would cost
-135i Coupe
--AW, sport, usb/ipod, hi-fi stereo
-Production # 6711168
-Delivery Date 9/15/2008
*just in time for oktoberfest in Germany!!!
      11-27-2007, 04:54 PM   #8
S62PWR
BMW CCA# 90345
Drives: 08 335i Cpe 6 speed
Harold, great stuff. Can you repost the Mechanical and Technology PDF's. They seem to be MIA. Thanks
      11-27-2007, 11:58 PM   #9
slipkmaggot
15
Drives:
....great read
.....if only i knew what it meant
:respekt:
      12-03-2007, 12:15 PM   #10
john970
1er
73
Drives: 08 135
PDF links broken.
      01-05-2008, 06:31 PM   #11
Oregon
NRA Life Member, BMW CCA 30 year member
Oregon's Avatar
Drives: 04' M3
1971 2002  [0.00]
2004 M3  [0.00]
2008 135i  [0.00]
Originally Posted by john970 View Post
PDF links broken.
Concur...
Resigned 1ADDICTS Moderator
“To disarm the people is the best and most effective way to enslave them.” – George Mason
      01-06-2008, 01:24 AM   #12
Harold
Drives: Z3 Coupe
PDF links broken.
Fixed. Thanks.
      01-06-2008, 10:07 AM   #13
Oregon
Oregon's Avatar
Drives: 04' M3
1971 2002  [0.00]
2004 M3  [0.00]
2008 135i  [0.00]
Thank YOU !
      04-16-2008, 01:32 AM   #14
absoluzer0
Drives:
Actually the blow off valve doesnt make a "disruptive pumping noise" Thats called compressor surge,. Have you ever heard what compressor surge sounds like? It sounds exactly like a "noticeable, disruptive pumping noise." A blow off valve makes a single noise of pressure relief.
      04-27-2008, 02:05 AM   #15
F82SO2
F82SO2's Avatar
33
Drives:
great read.. thanks for posting..
      05-14-2008, 07:29 PM   #16
adnb
adnb's Avatar
Drives: BMW 123d
Hello,
I've registered just to thank you on the intel...
Excellent post!
Do you have anything like that for the 2.0 bi-turbo diesel engine?
Thanks in advance!
      03-03-2009, 10:19 PM   #17
drumnatural
Drives: 135i future owner
Dear lord thats alot of info
      04-17-2009, 09:06 PM   #18
jeremydgreat
jeremydgreat's Avatar
Drives: 2009 135i
Kinda surprised no one has responded to this.
135i // M-Sports Package // RR Oil Catch Can // Black Kidneys // iCarbon Hood // Alum Pedals // KW v2 Coilovers // Vorshlag Camber Plates // Hotchkis Sway Bar // Wheel Studs. Best mod ever? Tires. 255's in front, 275's in back.
      05-01-2009, 04:59 PM   #19
TMR013
Opus Angelus
TMR013's Avatar
425
Drives: 2018 LBB M2
Anybody know the OEM that makes the turbos for the N54?
      05-01-2009, 05:14 PM   #20
jeremyc74
Drives: '08 135i Montego/Terra
Mitsubishi.
      02-02-2010, 01:19 PM   #21
DarthColin
DarthColin's Avatar
44
Drives: 2011 1 Series M Coupe
Does anyone know where to find the equivalent articles for the N55? That would be awesome. By the way, the documents were very informative.
Colin
      03-24-2010, 05:13 PM   #22
sdpauly
sdpauly's Avatar
18
Drives: 2010 135i, 2008 Taco
I too am curious about this. If I do a JB+ or a JB3 what will that do to the longevity of my engine? I am honestly pretty happy with the stock power of this car. I may not change anything at all...
