07-08-2007, 12:54 PM | #1 |
9
Rep 130
N52 Aftermarket Modifications?
As I understand it, the 230hp N52 in the 128i (and 328i) is essentially the same engine that produced 215hp in the E90 325i and 255hp in the E90 330i. apparently it's simply a software change that is responsible for the changes in horsepower.
Anyone know of aftermarket options for getting more power out of the N52 in the 128i? |
07-09-2007, 11:18 AM | #2 | |
27
Rep 290
I remember seeing a "chip" over at e90post.com for the 325i that gave it nearly 330i power. I would imagine there is one for the 328 to get it to at least 245 hp, then intake and exhaust should get you to about 260hp. But that's about it. The engine reaches it's peak hp at 6600 rpm I believe so not much use in a raised rev limiter. But if your going to spend around 2k for all those things, you'd be much better off buying the 135i. Have you driven a 335i? Go drive one. I've have mine for 8months now. It's a beast. And, it's getting great track time's, right there with the e46 m3 and rs4. The oner with better brakes, lighter, etc. will be great. Plus you get the m-springs. |
03-31-2008, 06:05 PM | #3 |
28
Rep 1,938
The N52 has been rated as high as 268 or 272 hp in stock form, depending on what source you're checking. (In the X3 and some other different models.)
Theres defintely more power to be had. |
03-31-2008, 10:26 PM | #4 |
Santa Fe Concorso
103
Rep 2,984
In addition, the e90 330i has a three-stage intake manifold as opposed to the 128/328 single-stage manifold.
09-12-2008, 03:41 PM | #5 | |
475
Rep 13,583
Drives: JB E92 335i
09-12-2008, 03:52 PM | #6 |
170
Rep 3,160
As James already mentioned above, just wanted to ad the addition of light weight wheels and suspension upgrades to reduce unsprung weight and rear squat then starting from a dig.
08-19-2010, 02:22 PM | #7 |
2283
Rep 12,565
Drives: Z4 M, X5, GX460
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
best way to get the 330i numbers is to upgrade to 330i components which is the 3 stage intake manifold as someone else mentioned. that plus software and you're good to go. intake and exhaust will have minimal effects.
08-19-2010, 07:52 PM | #8 |
194
Rep 1,457
Thanks for reviving this topic after almost 2 years
08-19-2010, 11:43 PM | #9 | |
647
Rep 2,051
And as for the software, who supplies this? |
08-19-2010, 11:49 PM | #10 |
647
Rep 2,051
Found this link that has some details on guys trying to do a 325i conversion to 330i with the 3-stage intake manifold and some ECU reprogramming. Haven't read the whole thing yet to see their results; will do later and report back. Here it is for anyone who is interested:
http://www.e90post.com/forums/showthread.php?t=37444 |
08-20-2010, 08:37 AM | #11 | |||
18
Rep 293
Drives: '21 M2C 6MT, '21 Charger Scat
So I see 2 possibilities. CAI + exhaust...... or Powerbox, but NOT both http://www.1addicts.com/forums/showt...highlight=128i http://www.1addicts.com/forums/showt...t=N51+powerbox |
10-20-2010, 07:38 PM | #12 |
Rep 24
Supercharger
I was wondering if anyone like Eaton makes a Supercharger made for the 128i? I like the 135i performance but think Turbos suck, are problematic and will eventually fail on you. Didn't BMW issue a recall on their turbos?
Ox
Previous Cars: 1987 325, 1999 323is, 2002 Z3, 2002 325ci, 2006 Cooper S, 2011 128i, 2013 128i Current Car: 2013 135is |
11-14-2010, 10:38 PM | #14 |
samuray
Rep 139
12-12-2010, 02:05 PM | #15 |
Rep 7
Hi there;
In Europe; there are some tuners to reprogram the ecu, get power numbers like of 130i/330 i In Belgium http://www.shiftech.be/ In Germany http://www.ds-motorsport.de/bmw-tuning/1er.html Greetings |
12-13-2010, 09:19 AM | #17 |
175
Rep 1,040
12-13-2010, 09:25 AM | #18 |
194
Rep 1,457
you are not going to get 7-10 HP with scoops. It is wrong to even suggest that..
