      05-17-2023, 01:20 PM   #1
QueenCityLurker
17
Drives: 2009 135I
Fitment question 18x8F ET35, 18x9 ET40?
I searched through the "Official" mega thread, couldn't find anyone running this fitment.
I'm on Bilstein B8s with Cobb springs.
I'm currently running style 269s with E82 fitment.
My style 269 specs are:
Front: 18"x7.5" +49mm with a 12mm spacer, so effective ET of 37mm. 225/40
Rear: 18"x8.5" +52mm with a 10mm spacer, so effective ET of 42mm. 255/35
I currently only rub over high speed bumps in the passenger rear corner only. Nothing else rubs.
My question is, if I move to the below wheel specs with the same tires, will I need a fender roll?
Front: 18"x8" +35mm, no spacer. 225/40
Rear: 18"x9" +40mm, no spacer 255/35
Thanks.
      05-22-2023, 08:57 PM   #2
bnace10
Drives: 2011 E82 135i DCT Lemans Blue
Front wheels will likely be okay, but the rear will definitely need a roll.
      06-13-2023, 11:46 AM   #3
QueenCityLurker
17
Drives: 2009 135I
Update.
Got the new wheels installed. My tires were low mileage so I stuck with the same tires.
Turns out I was wrong about the wheel spacers. They were 15mm at all 4 corners.
So my original set up was essentially as follows:
Front: 18"x7.5" +49mm with a 15mm spacer, so effective ET of 34mm. 225/40
Rear: 18"x8.5" +52mm with a 15mm spacer, so effective ET of 37mm. 255/35
I had the fenders rolled just to be safe on the new set up. I do not get any rubbing.
      06-15-2023, 06:21 PM   #4
Eyeman
Eyeman's Avatar
121
Drives: 2008 135 blk, blk, step
Congrats, and it looks great. I think you will be prone to rear rubbing if you run a tire that runs wide (like Michelin PS4S, etc). I'd order 245 rear tires on your next set if you change brands.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
      07-03-2023, 01:28 PM   #5
bnace10
Originally Posted by QueenCityLurker View Post
Update.
With those specs, you're pretty much running E90 wheel specs. From what I've seen, it's very car-based whether or not will induce rubbing.
Glad to see it's working well for you!
      07-12-2023, 06:02 PM   #6
Eyeman
Eyeman's Avatar
121
Nice. So you are very close. Next set of tires be careful if you decide to change brands. Also realize that you can probably factory add more rear camber if you need it.
      08-29-2023, 01:39 PM   #7
NickTheQuick
NickTheQuick's Avatar
Italy
15
Drives: BMW E82 123d 2012
Update.
Beautiful wheels choice
May i ask you brand are those? Im looking for some 359 replicas too
Can you confirm that they fit with no rubbing?
      08-29-2023, 01:42 PM   #8
NickTheQuick
Italy
15
Also is your car a 135i?
If its a 128i or lower the rear hub is different
135i hub is 10mm higher than 128i>>>
      08-30-2023, 07:40 PM   #9
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
Drives: 2013 128i LMB 6MT ZMP Slicktop
2013 128i  [9.58]
The width of 128i hubs is the same as the 135i.
Inertia is the enemy!
My car's photo history: https://www.1addicts.com/forums/show....php?t=1570551
      09-05-2023, 03:34 PM   #10
QueenCityLurker
17
Drives: 2009 135I
They're Avant Garde M359s.
They rub only slightly in the front right over occasional bumps because the suspension is so low in the front.
Depending on your front ride height, it may not rub.
      09-10-2023, 08:30 AM   #11
NickTheQuick
Italy
15
Avant Garde? They don’t make M359s in 8”/9” setup
They are either 8,5”/9,5” or another brand my friend
