04-04-2023, 07:20 PM | #1 |
89
Rep 97
Bad injector?
Got the following codes today as well as a drivetrain malfunction.
Rough idle, sounds like a subaru, etc... It all goes away when you turn the car off and returns when getting much accelerator input. Plugs and coil packs were done less than 6000 miles ago, already has an aftermarket chargecooler so those other common culprits seem less likely. e: have a log: https://www.bootmod3.net/log?id=642c...0b43923b7a4bc2 I have a couple longer ones as well. Last edited by fknlo; 04-04-2023 at 07:25 PM.. |
04-04-2023, 11:49 PM | #2 |
3291
Rep 6,732
Other than mine being cylinder 6, those in addition to a few others related to my O2 sensor failed, were what I got when my injector failed.
Take your plug out and look for wet plug. #5 is towards the firewall (back of engine). If there is a gas smell, you have a failed injector more than likely. |
04-05-2023, 12:59 PM | #3 |
5512
Rep 5,188
I say an O2 sensor because your Lambdas are far different. If it were an injector the STFTs would be far different, but they’re not.
It could also be a spark plug not tightened down well. I’ve seen them loosen and leak compression, which also causes misfires. Tighten to 25Nm…not 23.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
04-10-2023, 03:19 PM | #4 | |
89
Rep 97
It had popped the coil pack off as well. Luckily I have some spare plugs. Obviously gonna make sure they're all tight before I put it back together. |
TopJimmy5512.00 |
04-10-2023, 06:46 PM | #6 |
5512
Rep 5,188
I had a BMW Master mechanic teach me to tighten plugs to 25Nm instead of 23 because he was seeing that the crush washers weren’t crushing (showing a ring all around, instead of the sandpaper texture that they have before install).
Glad you found it!!! Is that a little arc burn up top from the loose coil pack?
papasmurf_m3454.50 |
04-10-2023, 07:10 PM | #7 | ||
89
Rep 97
https://www.bootmod3.net/log?id=6434...90c64d34d1773a Running better. Still has the timing thing that I've always had on the stage 1 tune. I had hoped it was more of an issue of the altitude and gas quality from living in Colorado but I'm no longer there. This tank is even 93. Maybe I'll get that figured out some day. |
