03-07-2023, 05:23 PM | #1 |
23
Rep 61
M4 long term storage
Hey guys, so I have a 2016 M4 that’s been sitting in my garage for a year and a half now and will probably sit for at least another year. I put new oil in it last spring and drove it around for about the equivalent of half a tank.
I just want to know what I need to do or be concerned about with leaving it for another year at the minimum. It’s sitting on a charger designed for li-ion batteries and it’s in an enclosed environment. It needs new set of tires anyways so I have no concerns with those. My main concerns are fuel since at least half of what’s in there has been in there since August 2021 and oil.
2011 BMW M3
2016 BMW M4 2010 BMW 335i |
03-07-2023, 06:23 PM | #2 |
379
Rep 212
Personally I wouldn't worry about the oil. At most, you can change the oil and leave fresh oil in there, but you'll be OK.
For fuel, i would fill the tank up and if you really want to, add a fuel stabilizer. Since you're not worried about the tires, and you have a tender you should be fine. Something I do when I store my car is close all of the air vents, and leave a open box of arm and hammer on the floor board for moisture. I do the air vents so little bugs can't make their way in. |
