02-09-2023, 02:03 AM | #1 |
Rep 29
coolant slow leak, expansion tank pressured
Hi guys,
i need some ideas for what's going on to my car, it's suffering from coolant leak - coolant leaks 1 cup every 2 weeks (weekly check), 500 to 600ml every 2 to 3 months (low coolant warning) - mechanic checked no sign of leaking on the hoses - mechanic checked pressure test of coolant, no drop personal findings not sure if it's related to any issue, but certainly coolant related - everytime the engine cools down next day, i try to open the expansion tank, it's pressurized. sound like opening a new bottle of coke. - no sweet smell from exhaust, only condensation on cool morning. - coolant surface doesn't have any oil sign. i've did searches, but i doubt the mechanic checks up to that level, probably did not check the deeper side - turbo coolant hose coolant expansion tank become pressurized like a bottle of coke is my concern what could be the issue. |
02-09-2023, 02:35 AM | #2 |
176
Rep 301
Drives: BMW M3
Leak in the tmic from what I have read Around here.
02-09-2023, 01:01 PM | #4 |
612
Rep 718
Drives: E46/F15/GT4
I had an internal leak in the TMIC that was replaced under warranty
02-19-2023, 04:15 AM | #5 |
Rep 29
it's not the TMIC... it's the main expansion tank that's water missing. and i can't smell anything from the engine bay... mechanic claimed they looked every hose.. no sign of leaking....
what's the probability the tiny leak at the turbo ? perhaps that area not easy to be spoted. |
02-19-2023, 08:39 AM | #7 |
5512
Rep 5,188
If it’s the engine coolant reservoir you just need to search really good for leaks or white residue buildup. Sometimes the expansion tank can leak at the side seams. I haven’t heard of any other “common” issues. My tank is also under pressure when I open it cold, so that seems to be normal.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
