      01-23-2023, 12:47 AM   #1
Max128i
Max128i's Avatar
Drives: BMW 128i
Widest tire on Style 256 17"?
What’s the widest tire a Style 256 wheel can hold?
      01-23-2023, 08:19 AM   #2
ZeroR
Track Addict
ZeroR's Avatar
16
Drives: 128i
For a 7" wide wheel like the style 256, I would stick to 225 tires. You can go wider than that but probably would not be recommended. Starting with a 235 size tire, it is usually recommended to have at least an 8" wide wheel minimum (or maybe a 7.5" wheel). Also trying to find an available tire in a 235 or 245 even, with around the same calculated overall diameter will likely be cost prohibitive or just not available on the market. 225/45/17 size tires are such a common size that they will be the better deal by far.
      01-24-2023, 09:24 AM   #3
Max128i
Max128i's Avatar
Drives: BMW 128i
ZeroR thanks! I’m on square 225/45/17s right now but wanted to know if any wider was possible with the stock wheels. They feel very good compared to the 205s.
I bought the car used not long ago and it had 205s on with little to no life remaining so I put on some used tires to make the car actually driveable. I am planning on buying a set of new tires in the near future and was wondering if I could go any wider.
What about spacers? I want to make the wheels as flush as possible with the least amount of rubbing possible
      01-24-2023, 06:00 PM   #4
Blau
J
Blau's Avatar
Drives: BMW 128i
2011 BMW 128i  [6.00]
2013 BMW X3 28i  [0.00]
Is it lowered at all? That will matter when you are using spacers. I have 10mm on my style 256's and it's not nearly enough. On my summer wheels (18x8) they're perfect.
      01-24-2023, 06:27 PM   #5
Max128i
Max128i's Avatar
Drives: BMW 128i
It’s not, it’s on stock suspension, so would you say 12mm or larger?
      01-24-2023, 08:08 PM   #6
Blau
J
Blau's Avatar
Drives: BMW 128i
Give it a shot! Also check out the Fitment Industries page. They may have more info. There are also ways to measure. You gotta dig through the forums.
